Old 03-06-2017, 07:29 PM   #11 (permalink)
ScanGauge <3
Winter Sacrifice - '96 Subaru Outback
Subaru
90 day: 20.98 mpg (US)
Originally Posted by luckyfool View Post
I am considering installing cold air intake on my 2007 Honda Civic LX for my first mod. I am planning to order the K&N cold air intake kit that I saw on 4wheelonline. Is it a proven way to improve a vehicle's fuel consumption and horsepower?
It can certainly help increase the car's fuel consumption, yes.
Best tank (so far): 32 MPG
Old 03-06-2017, 07:53 PM   #12 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.78 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.47 mpg (US)
Originally Posted by stovie View Post
I did, but like I said I live in a mountainous region and the lack of power caused it to loose mpg will the cold air increased my mpg due to not having to downshift from fifth anymore!!
I think at altitude it's not so much the temperature but the density of the air. You don't want to do anything that reduces the density of the already thinner air.
Old 03-06-2017, 10:04 PM   #13 (permalink)
Gaptooth - '00 Honda Insight
Gen-1 Insights
Except when you do.
Warmer air = thinner air = wider throttle plate, which is good in every situation except where the throttle is wide open and you need to downshift for a bit more power. At part throttle loads, colder and denser air will cause economy to drop. Warmer air also (generally) helps with combustion efficiency.
Fun bit, I seem to remember some of the old Honda CRX's having a factory flap which fed the engine warm air under light loads, and colder air as the throttle opened up. This gave the best of both worlds - economy when you need it, and power when you nee it.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
