Go Back   EcoModder Forum > AltModding > Saving@Home
Old 08-30-2010, 06:37 PM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Originally Posted by skyl4rk View Post
It sounds like the most economical way to do this would be to take an existing room and build an inner wall frame with ceiling and raised floor, and fill the wall space with insulation.
A staggered studwall and 8" of insulation would also result in an extremely quiet room. Here's one room-within-a-room construction built to be extremely quiet: An Anechoic Chamber for SPCR | silentpcreview.com
If this is for a hypothetical cabin, I'll assume it's not a large building. By the time you superinsulate an 8' square room (32' perimeter), you're a third of the way to superinsulating and sealing an entire 25'x25' house (100' perimeter). A DIY solar thermal collector can be built for a few thousand dollars, and would heat the home to comfortable levels without you having to light a fire.
Here's an ice fishing shack with a Trombe wall: http://builditsolar.com/Projects/Spa...arIceShack.htm
Old 08-31-2010, 11:24 PM   #12 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Ridged foam normally has a 15psi compression strength, so one square inch can support 15 pounds, 10 square inches can support 150 pounds, thus you can almost build an inner shell and an outer shell and have ridged foam in between and as long as it was built tight enough you wouldn't need any thermal bridging, so in theory you could get away with studs only at the corners and joints of your sheathing and not have them bridge the entire thickness of the wall.
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 03:39 PM
How to: reduce the rich condition of a cold start. C3H8 EcoModding Central 69 09-10-2010 03:53 PM
Cold engine start, high idle reduction mod saand EcoModding Central 12 08-17-2010 11:36 AM
How I can tell cold weather has arrived in the northern hemisphere MetroMPG The Lounge 11 12-09-2009 06:33 PM
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 22 04-07-2009 09:30 PM
