Old 10-13-2011, 02:33 PM   #1 (permalink)
Cold start fast idle delete
Hi,
I was wondering if anyone has gained any improvement by blocking off the cold fast idle valve, a separate valve from the IAC on 94' Accords? Currently my engine idles around 1500 rpms on cold starts and slowly works down to 800rpms as it warms. I'm thinking about plugging off to lower rpms on cold starts. One foreseeable scenario, is that the engine wouldn't reach open loop as fast and may negate the lower idle rpm fuel savings?
Also, my 94' is an OBD1 car, thus only one O2 sensor. So, would hollowing the cat bring gains in mileage?
Thanks in advance, Jig
Old 10-13-2011, 02:53 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Hollowing out the cat is not only illegal, but completely unnecessary. Unless it is plugged, its not hurting mileage at all. That, plus I like clean air.
I'd leave the fast idle alone too. Not only does it heat the car up faster for defrosting and heat, it also gets the engine warm so oil flows properly, the transmission warms up and reduces drag and also so you can get into open loop and stop dumping a super rich mixture into the engine just to keep it running.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Ryland (10-13-2011), some_other_dave (10-13-2011)
Old 10-13-2011, 09:52 PM   #3 (permalink)
Intermediate EcoDriver
Mustang Dave's Avatar
White Pony - '07 Mustang V6 Premium Coupe
Team Ford
90 day: 29.98 mpg (US)
Big Red - '89 F-250 4WD Custom
90 day: 15.54 mpg (US)
What's cold idle? Start it and drive; idling wastes fuel.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Old 10-13-2011, 10:36 PM   #4 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.61 mpg (US)
Silver Bullet - '00 Insight
90 day: 60.3 mpg (US)
Yup, what Dave said.
Use a block heater or an oil pan pad heater to get the engine up to operating temps faster. Even a trouble light with an incandescent light bulb slid under the engine will give it some preheat.
And don't idle!
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
