Old 10-04-2009, 12:09 PM   #251 (permalink)
Gen II Prianista
Rokeby's Avatar
Sweet,'lid, clean installation, well done.
All you need now are some rear wheel skirts for the high-zoot look,
and maybe 1 or 2 MPGs.
Old 10-04-2009, 12:39 PM   #252 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Bondo -
That truck looks great, man.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-04-2009, 01:11 PM   #253 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
Civic EX - '00 Civic EX
Send a message via Yahoo to bluetwo
Is there anything new with the areo bed cap? I havne't been here in a little bit and I was just curious.
Old 10-04-2009, 03:41 PM   #254 (permalink)
electricman
AeroCaps and Cooling Drag
Hey Brett aka Bondo, one thing I noticed - with the wedge caps, aerocaps, and aerolids, we have less drag, but also - less power required to simply drive and so - less heat in the engine: Stock Temp Gauge in my 2008 Dakota with the Aerocap of mine seems to never make it up to the 50% Temp Mark, usually running at about 35 - 40% of Max, no matter the Outside Air Temperature (OAT)!
So - it would seem to me that the required co-related mod would be the front grills intake airflow to be blocked, or cleaned up and reduced, so that the heat engine - actually heats up better! Less cooling drag = leass total drag = warmer running engine, and a cold engine at idle in my pickup runs about 4.2 Litres of fuel per hour (per the ScanGauge) versus about 1.9 LPH or even 1.7 LPH when idling warm (In neutral, with no tranny load, stopped at lights).
I am sure that if we started with the front airflow mod first - and then added the aerocaps of choice - that to get the temps back up to the 50% or mid-point would then require an update on the grill block, and adding a flat belly pan - further reducing drag would again require less power and need the front grill block updated once again. Same for rear wheel pizza covers or smooth hubcaps and the step up of rear wheel skirts.
Robert.
Last edited by electricman; 10-04-2009 at 03:45 PM.. Reason: Quick Post offers too little options.
Old 10-04-2009, 04:46 PM   #255 (permalink)
Originally Posted by WaxyChicken View Post
Google for "Angel Investors" these are rich people with money and nothing to spend it on. They will listen to proposels from various new inventors and small business owners and consider putting up the front money for projects.
I know some in my area. I'm saving their contact info incase i ever actually finish one of my inventions.
This is what i mean by the "Wife Test".
Rather than saying the wife said 'No' you say "I had a funding plan, but it failed the 'wife test'. "
I heard one called 'the testicle test.'
Anyone else hear about that one?
I'll just Google it whenever I get the time.
Don't give up Brett! You're ON the RIGHT track!
God Bless those with (and without) creativity!
GreenTruckingConcepts.com
Old 10-04-2009, 07:30 PM   #256 (permalink)
bondo's Avatar
New Aerolid
Thanks Rokeby and Christ for the compliments. Ford had changed the 2009 only slightly by extending the bed by one inch and raising the cab height by one inch. This made the retooling a lot easier than it might have been. Also, alot of the design elements of the 2004-2008 model F-150 were carried over into the 2009.
Engine operating temperature is definitley something to consider electricman. The cooling systems are tuned to allow the engine to operate at optimum BTU's. I have not noticed my truck running cooler but I am going to start paying attention to that. If the air intake can be blocked off some that would help reduce drag further. It is a good point that with each aero modification attention should be paid to any change in the cooling system. I think maybe as far South as we are in Arkansas our engines tend to run on the warm side anyway.
Nothing new to report bluetwo except that I have been contacted by a possible investor. It appears he made his money by winning the lottery. Good for him to be possibly willing to invest in manufacturing. At this point, I can use a good partner with a good set of hands who is willing to help me build the lids as much as I need capital. To lift the lid on and off the truck by myself to check fit and finish is getting hard on my 52 year old back. Not going to give up though Mandilon.
I'll be posting my fuel log results on the new Aerolid on my 2009 F-150.
Bondo
Old 10-04-2009, 08:26 PM   #257 (permalink)
This test vehicle ran cooler after this 'grill block.'
FoMoCo has incorporated a grill block on some test models (maybe they're allready in production vehicles).
Bondo, there's this Mel Francis out east that's an expert fiberglass designer and production expert that I lost track of.
I worked for him in El Rio/Oxnard California before he headed east. I lost his email. If anyone knows him or has a way of locating him let me know. I have a ton of fiberglass projects on the shelves and I need his help.
Bondo, I travel to east Texas (Austin, Dallas and Houston) on occassion. Maybe I'll pay U a visit since you're not too far from Dallas.
Does anyone have that drawing of a frog choking a snake that trying to gobble him up? The caption reads "Never give up!"
B carefull of snakes! (individuals that try to discourage U!)
Old 10-11-2009, 10:17 PM   #258 (permalink)
[QUOTE=GoodOak;121775]
The first thing it seems everyone there does is jack the truck up 3" and get bigger, burlier tires.
I don't think these are the people that Bondo wants to target anyway. Every inch of lift throws the FE out the door. For the price of 1 F150 you could buy 2 Ford Focus That each get double the mileage.
I drive my Focus because of the FE, If I could get my F150 to get 25 MPG I would leave the Focus home once in a while.
FYI: In 2003 I traded my 97' F150, 2WD, 4.2 v6, 5-Spd Manual w/OD averaged 17 MPG. Got a 2003 F150, 4x4, 5.4 V8, Auto w/OD averaged 17 MPG. I gained more power and off-road ability for the same fuel cost.
Old 10-14-2009, 09:52 PM   #259 (permalink)
bondo's Avatar
24.1 mpg!
Today was a good day for a road test. The winds were around 5 mph out of the ENE. The temperature was around 72 degrees. So, I drove to Texarkana, Arkansas and back, from Little Rock, a distance of 267.8 miles.
The website Fuel Economy rates my 2009 F-150 with the 4.6 liter two wheel drive at 20 mpg for highway travel. Today I burnt 11.1 gallons of gas to Texarkana and back or 24.1 mpg! I am stoked!
Some good things are developing on getting the aerodynamic cover to market. Todays road test, with the Aerolid gaining a 20% increase in the fuel efficiency of my truck, will help greatly.
Yeah fishaholic I'd love to get 25 mpg but I am not complaining about 24.1 mpg for a full size pickup truck with a V-8 engine. Had to take a picture of my truck after I parked it at the end of the road test.
Thanks to all,
Bondo
Old 10-14-2009, 10:03 PM   #260 (permalink)
I want to see 30 consistently from a full-size pickup, without extreme driving techniques. I mean simple stuff like slowing down, not starting the vehicle until you're ready to move. Beyond that, I want to see it with aero and efficiency mods, and still be able to use it for a truck if/when necessary.
Bondo, I love what you're doing here. Keep it up!
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/commercially-produced-aerodynamic-pickup-bed-cap-583.html
Posted By For Type Date
camper for my VW truck - Cheaprvliving Forum This thread Refback 11-06-2011 12:10 AM
You can't make it up! - Ford F150 Forum - Community of Ford Truck Fans This thread Refback 09-07-2011 06:07 PM
The Most Effective Way to Improve Gas Mileage This thread Refback 09-05-2011 10:38 AM
Need more space in the nose. Kodiak/Topkick parts maybe? This thread Refback 08-28-2011 11:00 AM
www.recumbents.com This thread Refback 08-24-2011 03:06 PM
Ecomodder site has new/old ideas - PowerStrokeNation This thread Refback 08-16-2011 12:23 AM
Colorado Slantback - Page 5 - Chevy Colorado & GMC Canyon This thread Refback 08-13-2011 02:05 PM
Customize your wheels : funny This thread Refback 08-07-2011 12:54 AM
hypermiling This thread Refback 07-23-2011 05:39 AM
Truck caps: do they improve fuel economy at all? This thread Refback 07-14-2011 10:08 AM
FORDSIX PERFORMANCE • View topic - Scale angled topper and wind tunnel This thread Refback 07-11-2011 10:07 PM
Whats your mpg (duratec ONLY) - Page 6 This thread Refback 07-04-2011 04:53 PM
mileage what you getting? - Page 4 - Ford F150 Forum - Community of Ford Truck Fans This thread Refback 05-29-2011 01:29 PM
Ecoboost "stutter" at idle - Page 2 - F150online Forums This thread Refback 05-22-2011 09:56 PM
Can a 1992 Ford F-150 get 20 MPG? - Yahoo! Answers This thread Refback 05-01-2011 01:24 AM
SpeedArena.com - Truck caps: do they improve fuel economy at all? This thread Refback 04-07-2011 11:41 AM
Truck caps: do they improve fuel economy at all? This thread Refback 03-28-2011 01:01 PM
VWVortex.com - Truck caps: do they improve fuel economy at all? This thread Refback 03-28-2011 01:01 PM
Pickup tailgate up or down - SAE Studied - Page 2 - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 03-25-2011 11:23 PM
Aerocivic - Honda Civic modifications for maximum gas mileage - aerocivic.com This thread Refback 03-16-2011 01:54 AM
Best parts mix for Power / Economy - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 03-02-2011 04:21 AM
The Recumbent Bicycle and Human Powered Vehicle Information Center This thread Refback 02-28-2011 09:54 AM
How to get better mileage - Page 4 - Dodge Cummins Diesel Forum This thread Refback 02-21-2011 06:53 PM
Pickup Aero Bed Cap - Aero Bed This thread Refback 02-11-2011 02:37 AM
Low rider - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum This thread Refback 02-03-2011 11:09 AM
Any advice on truck caps? (aka camper shells) - Page 3 - Airstream Forums This thread Refback 01-05-2011 09:06 PM
Dodge Cummins Diesel Forum - View Single Post - Better MPGs ?? This thread Refback 01-02-2011 08:50 PM
Dry Lakes Racers Australia • View topic - Mals Effie project This thread Refback 12-21-2010 06:37 PM
Dodge Diesel - Diesel Truck Resource Forums - View Single Post - Best parts mix for Power / Economy This thread Refback 12-07-2010 10:02 PM
HOT ROD Fuel Economy - Hot Rod Magazine Blog This thread Refback 11-28-2010 10:47 AM
Best parts mix for Power / Economy - Page 2 - Dodge Diesel - Diesel Truck Resource Forums This thread Refback 11-17-2010 07:03 PM
Fuel Foes: September 2010 This thread Refback 11-16-2010 11:32 AM
Fuel Foes: Aerodynamic pick up bed cover. This thread Refback 10-07-2010 03:01 PM
19 Interesting facts About America - IndustryWeek Forums This thread Refback 09-30-2010 04:36 PM
Fuel Foes This thread Refback 09-10-2010 02:28 AM
Chevy Colorado & GMC Canyon • View topic - Colorado Slantback This thread Refback 08-25-2010 02:03 PM
Whats your mpg (duratec ONLY) This thread Refback 07-30-2010 04:25 PM
Dry Lakes Racers Australia :: View topic - Mals Effie project This thread Refback 07-09-2010 04:44 AM
Aero civic - Expedition Portal Forum This thread Refback 07-07-2010 06:00 AM
Truckblog - Alternative Aerodynamic Camper Shell Helps Increase Pickup Truck Fuel Efficiency This thread Refback 06-01-2010 06:50 PM
GM pickups to adopt active louvered grilles for fuel economy? - Autoblog Green This thread Refback 05-19-2010 02:33 AM
GM pickups to adopt active louvered grilles for fuel economy? — Autoblog Green This thread Refback 05-18-2010 10:26 PM
Truck Tailgate fuel efficiency - Topic Powered by Social Strata This thread Refback 04-26-2010 10:54 AM
Alternative Aerodynamic Camper Shell Helps Increase Pickup Truck Fuel Efficiency - Truckblog This thread Refback 04-08-2010 11:57 PM
Pickup Aero Bed Cap | Aero Bed This thread Refback 03-27-2010 12:17 AM
Pickup Aero Bed Cap | Aero Bed This thread Refback 02-19-2010 01:08 AM
Pickup Truck Aerodynamics | Tech Blog & Discussion at Popular Hot Rodding Magazine This thread Refback 02-11-2010 09:35 PM
Solar panel direct charging guide - Page 5 - DIY Electric Car Forums This thread Refback 02-10-2010 11:34 AM
Team B.A.T. - References This thread Refback 01-25-2010 03:23 PM
Pickup Aero Bed Cap | Aero Bed This thread Refback 12-27-2009 12:56 AM
Boat Shrink Wrap? - Completely non-boat use? - CK5 Forums This thread Refback 12-14-2009 11:40 AM
The Most Effective Way to Improve Gas Mileage This thread Refback 12-07-2009 12:00 AM
DodgeForum.com - View Single Post - 2003 4.7 V8 Dakota Quad cab, how can I get better MPG? This thread Refback 12-06-2009 10:51 PM
2003 4.7 V8 Dakota Quad cab, how can I get better MPG? - Page 4 - DodgeForum.com This thread Refback 12-06-2009 09:58 PM
2003 4.7 V8 Dakota Quad cab, how can I get better MPG? - Page 3 - DodgeForum.com This thread Refback 11-28-2009 11:54 PM
Pickup Truck Aerodynamics - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 11-03-2009 10:41 PM
Need helping finding a truck cap - BoatingABC.com This thread Refback 09-03-2009 09:54 AM
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 03:35 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
How much do y'all pay for trash pickup? roflwaffle Saving@Home 15 08-23-2009 11:46 AM
Daihatsu Mira aerodynamic modifications newtonsfirstlaw Aerodynamics 5 06-13-2009 10:43 PM
Easy Aero Fix? (Modding a pickup?) DifferentPointofView Aerodynamics 51 05-30-2008 11:43 PM
