Compact camper alternative: New Beetle TDI with hard mounted pop up tent
here is the little TDI Beetle with the new CVT Roof Top Tent as I couldn't find a tent trailer small enough that i liked!
http://i40.tinypic.com/2expjsm.jpg |
Neat! That looks pretty well thought out with the generous awnings over the window and entrance.
Did you get a picture of the frame without the canvas? Or does it not work that way? |
HHOTDI, that's an interesting tent! Do you stow the tent inside for driving, or does it fold up and stay on top? If it stays on top, that will add a lot of drag and frontal area, lowering mpg :(
You could mount that tent on a small utility trailer like those shown on this thread and tow it behind, better mpg...also you wouldn't have that ladder to climb. Quote:
http://i42.tinypic.com/2ngrc0g.jpg |
new CVT areo mounting location
http://i42.tinypic.com/wail3q.jpg http://i41.tinypic.com/2h5703k.jpg http://i42.tinypic.com/fxgj0p.jpg |
i'm digging the rack, well done!
Seriously, that's awesome. What will you think if your gas mileage goes up?
I'm curious about how you did the brackets on the C-pillars, but the only way I see to improve it would be if the vertical member was an electric screw jack. Can you feel the weight re-distribution out on the highway? |
Thanks all, I appreciate the comments. I don't mean to highjack the thread... I simply made 1/8" plate for the C pillar brackets and used to nice/large stainless screws to attach each of them. Five screws each side with the brackets bent outward as they exit the hatch so the hatch will open/close with them still on. I attempted to design the mounting rack so the hatch would still open, but that placed the CVT tent too far back. There is no noticeable change in the drivieability/handling characteristics, even at freeway speeds. You do have to watch out for Tail-Swing though when you maneuver in and out of tight parking spaces! In the one picture, you can see where I placed a block of wood under the hitch for stabilization when the CVT Tent is set up for use. That cured the vehicle's suspension softness and rocking/sideways motion almost completely. easy to do too. I spent about $25.00 in steel tubing and $40.00 in wal*mart Textured rattle-can paint. The donor 2place bike rack was a craig's list find for $25.00 and fit nicely. The upper portion of the rack simply unbolts and I was able to use the rest for the new CVT Hitch rack! if someone knows how to start a new thread, i'll post pictures of the build and answer any questions you/they might have and help as I can with others who may be interested if they wish. We love the CVT Rooftop Tent, they are so comfortable...and pretty cool too! thanks again, Mike :{)
Good camper alternative.
Be sure to attach a red flag or orange ribbon to the back, pretty much every state requires anything that protrudes from the rear of the vehicle to be flagged. |
HHOTDI: mind if I split your project into a new thread? It's definitely threadworthy, especially compared to version 1.0 (on the roof)!
