Old 01-18-2012, 07:31 AM   #1 (permalink)
318iS - '95 318iS
Team m8
90 day: 34.36 mpg (US)
Track Slag 535 - '89 535i Sport
Team m8
90 day: 19.12 mpg (US)
328 Shooting Brake - '97 328i Touring SE
Team m8
90 day: 24.32 mpg (US)
Compensating for New tyres? Calculating the % out my milometer will be..
Hi,
I've just replaced 2x 205/60/15's with 1.6mm of tread
for 2 new tyres of the same size with appox 9mm of tread.
My BMW takes its milometer feed from the diff, so the increased circumference of the new tyres will change that..
whats the best way to factor in the % difference, or does anyone know a way to calibrate an electronic speedo/milometer?
thanks
My BMW 328i Mods thread
http://ecomodder.com/forum/showthrea...ead-21561.html
UK MPG for the 328i Shooting Brake
US MPG for the 328i Shooting Brake
UK MPG for my 318iS (currently piloted by the Burd...)
US MPG for my 318iS (currently piloted by the Burd...)
Old 01-18-2012, 02:00 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...does Scotland have "mile-post" markers? If so, simply drive at steady 60 mph (using cruise-control helps) and measure the time (stop watch) between 1 and 2 mile posts.
MPH(x) = 3600 / sec for "1-mile" marker
MPH(X) = 7200 / SEC for "2-mile" marker
...the "correction" factor (%) will be:
% = MPH(x) / 60 mph or % = MPH(X) / 60 mph
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
Old 01-19-2012, 12:21 PM   #3 (permalink)
euromodder's Avatar
Hδgar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by 320touring View Post
I've just replaced 2x 205/60/15's with 1.6mm of tread for 2 new tyres of the same size with appox 9mm of tread.
You could use a GPS to calibrate the meter.
BMW likely calibrated it with fresh tyres though.
Lifetime fuel consumption :
Old 01-19-2012, 02:41 PM   #4 (permalink)
318iS - '95 318iS
Team m8
Team m8
Team m8
cruise control?unfortunately not...
cheers for the formula though
Fair shout- I may try to get my dad's one..
Old 01-21-2012, 03:28 AM   #5 (permalink)
D.O.G.'s Avatar
Zed - '81 280zx 2+2
90 day: 22.25 mpg (US)
Baa - '98 323 Astina Shades
90 day: 38.17 mpg (US)
The previous owner of my Mazda Astina (323F in Britain) fitted smaller profile tyres (195/50 15 verses 195/55 15).
I checked the speedo against my GPS on the motorway and it reads about 4.5% fast, as expected.
I checked the odometer against a measured 5 kilometer "speedometer test" sign posted on the motorway and found it to be accurate.....Huh?
I checked the odometer against the GPS driving to work. The GPS said my commute is 51.9km, my odometer said 52.0km, close enough to perfect. Again I say.......Huh?
My point is, don't assume the speedo accuracy reflects the odometer accuracy, as I always did in the past.
If you really have to adjust your speedo, this might help.
Speedo Corrector MkII Kit "Kit Back Catalogue" - Jaycar Electronics
I haven't tried this kit myself, but it sounds OK.
