Old 05-31-2008, 07:45 PM   #1 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
complete exhaust replacement on the Paseo
Well, the time has come. The existing exhaust on the Paseo is pretty much shot and needs to be completely replaced. I don't want to deal with this again anytime soon so I'm looking to remake it with stainless. However, I also don't want to spend a small fortune on the system so I'd love some recommendations. I'm looking for anything useful here. Mufflers? Cats? Resonators? Flex pipes? I'm doing everything from the exhaust manifold back so there are a bunch of parts that I'll need.
Old 05-31-2008, 08:17 PM   #2 (permalink)
Blue - '-1823 P/U
are you going to own it long enough for the extra $$ on SS ?
Old 05-31-2008, 08:33 PM   #3 (permalink)
CM400E - '81 CM400E
I don't anticipate selling it anytime in the near future. It only has 75k miles on it. Plus, in my wonderful salt using state a mild steel exhaust lasts about 2 years max.
Old 05-31-2008, 09:00 PM   #4 (permalink)
Blue - '-1823 P/U
i'd use mandrel pipe and plan on about a 1/4" or more increase in pipe dia. to start with
Old 05-31-2008, 09:36 PM   #5 (permalink)
CM400E - '81 CM400E
Why would you recommend a 1/4" increase in pipe diameter?
Old 05-31-2008, 09:39 PM   #6 (permalink)
Blue - '-1823 P/U
less backpressure,,but still good flow
Old 05-31-2008, 09:55 PM   #7 (permalink)
CM400E - '81 CM400E
Thanks, but I would have to disagree. My engine never sees more than 3000 rpm which is half of the max rpm. So, the exhaust is already oversized as far as I'm concerned. Thanks for the suggestion though.
Old 05-31-2008, 09:59 PM   #8 (permalink)
Blue - '-1823 P/U
cool than just build it like stock only in SS
Old 06-01-2008, 12:20 PM   #9 (permalink)
bhazard's Avatar
The TC - '88 Thunderbird Turbo Coupe
90 day: 28.03 mpg (US)
Well if its already oversized you wouldnt mind a 1" pipe on there then?
BP+T/G5MR swapped '93 Festiva
Escort GT Block, Garrett T3 50trim, A/R .42/.48
SRT-4 Intercooler
---Bests with BP+T---
1/4 mile ET - 12.99
1/4 mile MPH - 109.8
Best MPG - 36.8
Average MPG - 31 (over 11,500 miles)
Old 06-01-2008, 12:29 PM   #10 (permalink)
Blue - '-1823 P/U
if it only turns 3k that may do it ,,plus lighter and cheaper
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 08:44 AM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Can I get 60 mpg out of my Paseo? Daox EcoModding Central 16 03-03-2008 07:13 AM
MetroMPG.com mailbag: various questions (final drive, exhaust, underdrive pulleys...) MetroMPG EcoModding Central 0 02-23-2008 08:40 PM
