Old 10-09-2009, 03:34 AM   #1 (permalink)
White 4Runner - '98 4Runner SR5
90 day: 23.21 mpg (US)
Grey Jetta TDI - '011 Jetta
90 day: 42.45 mpg (US)
Computing FE Question
When computing your MPG do you use the odometer in your car or go off the ScanGaugeII? Just discovered that due to non stock tires that I had to adjust the speed on the ScanGauge +2%. I computed the difference and then confirmed it using a GPS and the SG set to KPH. So do I use the mileage from the SG from now on?
Old 10-09-2009, 03:36 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
According to some the SGII can go sightly out of whack over time, so I just use fillup, since even small variations will eventually filter out.
Old 10-09-2009, 03:39 AM   #3 (permalink)
I guess my question is do I use the tank mileage from the SG or still use the odometer? The odometer will report 2% fewer miles then actually driven.
Old 10-09-2009, 11:20 AM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I apply a correction to my car's odometer reading when calculating fuel economy of each tank.
My odometer reports lower than actual, due to swapping the transmission from a model that had different size tires.
I also have a speed (distance) offset entered in the ScanGauge, but it's less accurate than my own calcs against the odometer because you can't enter tenths of a percent when entering the offset.
Old 10-09-2009, 01:02 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
srortega -
I have the same +2% issue. I use my odometer and I calculate the +2% in my fuel log. It's like a little bonus every time I enter my fill-up data.
CarloSW2
American Solar Energy Society
Driving the Scanguage for FE Harry6 Hypermiling / EcoDriver's Ed 12 04-02-2010 01:51 PM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 01:50 AM
FE Acceleration thought experiment. TestDrive Hypermiling / EcoDriver's Ed 2 01-28-2009 11:24 AM
Looking at buying a civic vx. FE question yoshimitsuspeed General Efficiency Discussion 2 07-23-2008 07:50 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 12:38 PM
