Old 12-21-2007, 09:37 PM   #1 (permalink)
XFi
Driving NOW
XFi's Avatar
Now - '07 Accent GS
Xspire - '97 Aspire
90 day: 47.9 mpg (US)
Considering 15x3.5 'Skinnies' Wheels
What are your thoughts on these?
http://cgi.ebay.com/ebaymotors/ws/eB...m=260179364983
I was looking for LRR wheel/tire options and ran across these (and considering them).
I called and the rims are approx 10lbs each (similar weight class as VX and HX rims, but 15").
Besides the drag tires listed, a 135r15 vw tire or even 125r15 antique tire (Firestone & Michelin make them) would fit great and weigh in around 12lbs.
I know they aren't DOT, but they are for racing and rated at 1,000lb+ weight on each rim.
Besides the obvious expense, do you think that going even skinnier would lower the Rolling resistance and increase MPG. Or is it not worth the possible saftey concern?
They would look great on the UnNamed Wagon I could use them on 'Now' until Spring!
XFi
Old 12-21-2007, 10:27 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I'd be concerned about reduced grip for handling. And unfortunately the only way to know how bad it would be is to spend the $ first. Or... you could install 4 space saver spares. Ask Peakster about that - he tried it.
Old 12-21-2007, 11:01 PM   #3 (permalink)
Peakster's Avatar
'99 Intrepid - '99 Intrepid
90 day: 23.1 mpg (US)
I felt that the Geo had lots of caster when 2 donut tires were placed in the front (especially on gravel roads). With the skinny tires in the rear handling was okay. Borrow some donut tires from someone and see how they feel with your car.
Old 12-21-2007, 11:09 PM   #4 (permalink)
XFi
Driving NOW
XFi's Avatar
Now - '07 Accent GS
Xspire - '97 Aspire
Thanks, I may do that before $pending that kind of money.
XFi
Old 12-22-2007, 10:43 AM   #5 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 42.99 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 106.98 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
The price is prohibitive, $600 for 4 wheels, ouchies! Not to mention the +10 offset will stick the rim out from the hub a little further than wanted.
A suggestion: Dismount the spare tires from the spare rims and weigh them. If the weight is low enough experiment with those since the offset is more desirable. You might be able to find someone that will mount regular tires on a spare tire rim for you.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
