Old 11-30-2008, 05:17 PM   #1 (permalink)
01 Insight - '01 Insight DX
90 day: 67.82 mpg (US)
Considering an MPGuino...
I currently have a scangauge in my Honda Insight. But I would like some thing with the potential of a little more accuracy as I would guess monitoring the injectors would tell weather or not you are in leanburn?
My main question is, how hard would it be to monitor the LAF sensor? From the reading I have done, the constant voltage is .45 and the sensor has a range of 1.5 volts, positive is a lean mixture and negative is a rich mixture.
InsightCentral.net - Encyclopedia - Honda Insight Lean-Burn Oxygen Sensor
How would one go about hooking this up to an arduino? My goal is to have some sort of data logging in the end.
Thanks!
[edit] *****
As a not I am fairly new to the arduino. but from the time I have played with it, it seems fairly simple as far as programming it. just need help on the electrical side of it.
Old 11-30-2008, 05:31 PM   #2 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
An inexpensive route would be to purchase a generic gauge that handles those voltage ranges, and install per the schematic on the link page. Some additional components might be required depending on the gauge (resistors, etc.)
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 11-30-2008, 06:01 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
The MPGuino monitors fuel injector activity. It doesn't know/care whether the vehicle is in leanburn; it just reports how much fuel is used at speed and fuel consumption is calculated from there.
I've seen it working in Ben's lean burn-equipped, VX-engined CRX.
As for making just a lean burn indicator, talk to TomO - he's made a circuit for his VX. Not sure if it's 100% compatible with the Insight, but worth an ask.
Old 11-30-2008, 08:16 PM   #4 (permalink)
Thanks for the replies!
Perhaps I will have to order a kit and figure out the o2 sensor later.
Though I think I have a plugged fuel filter or a dieing/pluged injector. Under acceleration my xgauge shows a way lean condition.
Here's hoping its just the filter.
Old 07-08-2011, 04:27 PM   #5 (permalink)
mtgeekman - did you ever end up installing an MPGuino in your car?
I'm looking for installation tips settings for my 2000 Insight (Got a new UFO*: 2000 Honda Insight 5-speed (ailing IMA hybrid battery pack) )
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 03:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
Modding the MPGuino ac7ss OpenGauge / MPGuino FE computer 5 11-18-2008 03:40 PM
Some suggestions and notes on the MPGuino SVOboy OpenGauge / MPGuino FE computer 4 08-01-2008 08:00 AM
