Old 09-09-2009, 09:35 PM   #11 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
...the Insight goes "...furthest..." on a gallon is way too simple for unsophisticated readers (duh) to read or understand. What?
...it's simple, really: you accentuate the POSITIVE and they'll accentuate the NEGATIVE. So, which is it, poor representation of the facts or biased writing, or both?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
The Following User Says Thank You to Old Tele man For This Useful Post:
bryan11 (01-29-2010)
Old 09-09-2009, 10:16 PM   #12 (permalink)
saturn - '99 sc1
90 day: 35.67 mpg (US)
on the upside... people like pictures charts and graphs. anyone that should be allowed on the road should be smart enough to see that the insight gets the best mileage at each given speed vs. the competitors listed.
the few who thoroughly read the article will almost undoubtedly come to the conclusion that the writer is a fool.
Old 09-10-2009, 09:15 AM   #13 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Edmunds ran a mileage test and got these results:
Then Consumer Reports gave us the Honda Insight mph vs MPG for ranges that I'd already been tracking for the Prius NHW11, NHW20 and ZVW30:
Note that I do not consider Consumer Reports conclusions terribly helpful; not when we have three Prius models to compare to the Insight.
An Australian magazine also ran a head-to-head mileage test:
Finally, there are the EPA results from individuals:
What I'm seeing is the speed range, 70-75 mph, is key to a higher EPA mileage rating. The ZVW30 and NHW20 Prius do and they have an excellent EPA rating. But the NHW11 does not and it came in pretty low. So too did the Honda Insight.
I am fairly certain that BSFC at high power settings is the single most important aspect of highway performance. This is something the diesels share, a high BSFC at high power settings. Of course the diesels fall down in the city but that is something they will have to address.
Bob Wilson
Local record
The Following User Says Thank You to bwilson4web For This Useful Post:
MetroMPG (09-10-2009)
Old 09-10-2009, 09:48 AM   #14 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by bwilson4web View Post
...the diesels fall down in the city but that is something they will have to address...
I can address that, any driver can address that, more efficiently than a hybrid even, with just their brain
Oh, wait, U.S. Consumers, nevermind...
Old 09-10-2009, 10:48 AM   #15 (permalink)
...beats walking...
...uh, how many KILOMETERS to a MILE? or was that LITERS-PER-FURLONG?
...my (YMMV) simplistic summary:
A) hybrids do better in CITY than on HIGHWAY, while...
B) IC-vehicles do better on HIGHWAYS than in CITY.
...and, predominately IC-vehicles don't "...run out of steam..." at >65 mph as small-engined hybrids do (notice the current, larger engined Prius doesn't follow the same downward trend of its two predecessors).
Old 09-10-2009, 03:23 PM   #16 (permalink)
Why would high throttle settings have any impact on highway FE? When you're at a steady speed on a flat highway, your engine is only generating about 10-15 HP. That says a very low throttle setting to me.
High throttle settings would be useful in getting up to a given speed, so they would be used more frequently in stop-and-go driving. Like in a city with lots of stop signs and traffic lights.
-soD
Old 09-10-2009, 05:03 PM   #17 (permalink)
Engineering first
Originally Posted by some_other_dave View Post
Why would high throttle settings have any impact on highway FE? When you're at a steady speed on a flat highway, your engine is only generating about 10-15 HP. That says a very low throttle setting to me. . . .
This graph includes the power curve for my NHW11 and is not far off from the NHW20 and ZVW30:
You'll notice that:
70 mph -> 25 hp
75 mph -> 30 hp
But that assumes flat land and most roads, even on river bottom, have small dips and rises. These variations push the power requirement up quickly and that is where the inefficiencies come it.
At 10-15 hp, I'll be in the 45-55 mph range, which is great for performance but not what the EPA nor the most reviewers are actually driving. In fact, there are dead stops in the Euro, 'intra-urban' cycle, and though I don't have the EPA profile handy, I thought it had at least one dead stop.
A good theory, it seldom works out in practice. Too much of the energy goes to heating the brake pads.
Bob Wilson
Local record
Old 09-10-2009, 05:53 PM   #18 (permalink)
...beats walking...
...the same reason that parachutes "work" is why going faster takes more "energy" (HP).
...similarly, air resistance approaches 'solidity' (incompressability), ie: going "faster" requires exponentially more HP as you approach Mach 1.0 at sea level.
...the fact that the FE of four of the cars remained almost linear between 55 and 75 mph means their losses were FAR less than typical.
Old 09-10-2009, 06:19 PM   #19 (permalink)
Looks like the misinformation campaign hit its stride with the nitwit online media.
Consumer Reports tests fuel efficiency vs. speed; Honda Insight biggest loser — Autoblog
Old 09-10-2009, 10:00 PM   #20 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Bob - thanks for posting that info-fest. Good stuff.
tjts1 - yes, I've seen the headline & skewed Insight conclusion spreading as well. Here's another random example: Consumer Reports tests fuel efficiency vs. speed; Honda Insight biggest loser - GupShup Forums
Reviving a 2000 Honda Insight "beater" Red Hybrids 201 01-06-2012 12:42 AM
Honda Insight owner slows down: MPG up 14% MetroMPG Hybrids 4 11-28-2009 06:44 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
Tested: speed vs MPG - 2006 Toyota Corolla automatic MetroMPG General Efficiency Discussion 23 01-22-2009 12:54 PM
Honda Insight Debuts at Detroit SVOboy EcoModder Blog Discussion 0 01-12-2009 09:50 AM
