Old 04-24-2009, 08:45 AM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
That sounds like a lot of fun theunchosen! I wish I had the time to do that kind of stuff. I also wish I had an engine or chassis dyno at my disposal.
Old 04-24-2009, 09:17 AM   #12 (permalink)
An engine dyno would be nice in this situation, but I kind of have something close. . .
My grandfather(not the one with the Porsche) has more or less a private junkyard of cars. At least a hundred. Most of them are 60s models but there are some newer and some of them are my old cars(which I will stake a claim on the engine for this project).
He also has several generators rated for different amounts of power. one is 75KW and they are all not fully assembled as you would buy them. He has them in a bank of engine-driveshaft-generator so he can use a common fuel tank(In ground and massive like you find at your local Shell). My plan is to just mate the shaft of the old Taurus to the 75 and not gas it very hard at all for the tests since the danger zone is at very lean mixtures which the engine is only going to accomplish at low-rpm-low-fuel. Oh and then just measure the power output of the generator. It won't be an even match because its converting it to AC but I don't need an absolute reading. . .I just need the relative amount of power that the lean burn gets. So I know what the Taurus v8 produces at X(big) rpm, it produces x(little) AC electricity and the lean burn produces this percent less of x(little).
He is likely going to hate me because I don't really have time to do this either but since I don't have to take tests or study over the summer I can afford to sleep only a few minutes a night ^_^
Really its not about the power curve or the relative power though. As long as I can watch the DMM and see its producing an even power supply I know its working(no check engine lights on my non-existant gauge cluster). The test is for survivability to make sure this won't kill my B series, which is important. The Taurus V8. . .not so important.
Old 04-27-2009, 12:20 AM   #13 (permalink)
Try using a water injection system with your lean burn. I've been doing some research and found that it can replace approx 10-12% of the fuel and may also allow you to push lean burn leaner. An added bonus is that it should reduce NOx emissions as well.
If your looking a the typical honda lean burn engine math says you'll want about 16cc/min of water injection, and it will have to be triggered by lean burn engaging via a relay or something. It's my lastest brainstorm to try and get more out of the lean burn setup.
Old 04-27-2009, 08:05 AM   #14 (permalink)
Speculation on why thats beneficial to the engine?
I'm guessing the cylinder is going to go through the saturation dome at some point before ignition and if it does this would drastically cool the cylinder charge.
I suspect the benefit is created because the cooler mix is more flammable than the hot mix(air at temperatures close to oxygen's boiling point is much more flammable)?
Any other reasons?
I'm asking because maybe it can be done more efficiently. Also any potential dangers? As long as the water does stay that long it won't have time to cause/assist in serious oxidation but I suspect it might make the pistons and cylinders more brittle?
Old 04-27-2009, 11:14 AM   #15 (permalink)
The way I understand it, the lean burn pushes the AFR to the limit of detonation, which is caused by some part of the engine inside the combustion chamber getting too hot obviously. The water injection helps cool the internals to prevent detonation. A friend of mine was running a turbo kit on a stock 1.5L sohc civic engine at 15 psi, he got away with it because he ran water injection. For over 2 years it survived, but one day he forgot to fill the water injection and popped the head gasket. Surprisingly everything else was ok and actually very clean inside, no carbon buildup on anything. Something to do with the quenching effect doesn't let the carbon build up. The only danger is having the water inj. system improperly setup and having it hydrolock the engine.
Old 04-27-2009, 11:34 AM   #16 (permalink)
To avoid the lock I would go low and keep the charge as cold as is possible, I'm thinking maybe CCAI.
I can see the water having the quench effect, if something gets too hot, as well as the evaporative cooling, but I had not thought of it.
I would gamble the water injection is able to absorb some of the carbon debris to reult for his cleaner engine.
For the CCAI. . .
Massive hood scoop on the left side of the hood/engine bay, jack the pressure up, run it through(The AC cooling fins are on this side and are removed now) a pre-cooler, charge it(15-20 PSI), another cooler(more aggressive) BMPC, pressure release valve down to 3-4 PSI to drop AIT to 30-40 degrees lower than ambient, inject/drip water, valve. The assembly runs from left to right with the turbo mounted lower to reduce the amount of bending to merge the pipes, the second pre-cooler would be mounted along the bottom of the car with alot more area and then up to the intake tubing(maybe with some venting to additionally cool the air as it travels towards the release valve).
Old 04-28-2009, 11:20 PM   #17 (permalink)
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Too complicated - but do it
umm... I think you are making this too hard
water injectors are old school - like WWII propeller war bird old
many of the real high performers had water injection
Why does it work?
a little sprits of water goes in liquid and boils in combustion
and comes out a big puff of hot steam
- the steam comes out hundreds of times the size of the liquid water that went in
it also evens out the temperature spike of combustion - gentler but stronger bang
- all because the latent heat of water is freaking hugh
why is it clean inside - because you are steaming the cylinders
Normally This works best for engines and high throttle settings
a car at cruise or idle power is not going to see much benefit
but with lean burn maybe it would help
you could probably test with a rather primitive set up (spray nozzle in intake)
Go for it
Concrete
Start where you are - Use what you have - Do what you can.
Old 04-28-2009, 11:33 PM   #18 (permalink)
Why does it work?
Go for it
I researched a bunch of info on the net and also had friends making big HP with water injection, both N/A high compression setups and boosted cars.
That's what I was thinking, try running a mister setup like we use on the milling machines off of a compressed air canister and see what happens. At cruise, I agree it's pretty pointless, but in lean burn could be beneficial.
Old 04-29-2009, 08:07 AM   #19 (permalink)
I'm thinking initial test(to make sure the gnine is surviveable) on a weed eater. That said I'll have to jury rig the carb to make sure it doesn't flow WOT fuel as well. Its a junker so I don't mind if it goes(10 bucks). If that works out smooth I'll test on the Taurus with water injection, and if that works out I'll bump to the Del Sol and see what happens. Prefer to keep my daily driver able to do just that.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
Lean Burn all the way! brucepick Success Stories 67 04-29-2012 06:44 PM
lean burn rules~! coolwHip Introductions 42 10-01-2011 05:42 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Fooling the ECU to burn lean... metromizer EcoModding Central 32 01-04-2009 04:26 PM
