Old 04-19-2008, 05:56 AM   #1 (permalink)
Look ma I can coast
Sethro's Avatar
Sethro's 626 - '88 626 LX 5 door
90 day: 36.27 mpg (US)
Converting 4wd to 2wd hybrid?
Image says it all:
Not sure it this is doable with ratio's, transaxle, etc. But what a way to go. I mean you could easily use regeneration in this system.
Old 04-19-2008, 11:44 AM   #2 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
I think Lexus or or one of the auto mfr's did something like this... But not for driving, it was used for traction control....
Challenge me, or correct me, but don't ask me to die quietly.
Old 04-19-2008, 03:07 PM   #3 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
great idea put motors on all those shafts
remove center section of independant rear
install double shaft motor with over running clutches in shafts
eliminates all rear gear losses
old subaru would work great
Old 04-20-2008, 02:03 PM   #4 (permalink)
Lurking footless halls
Silveredwings's Avatar
Orient Blue - '02 325Ci Convertible
Originally Posted by Sethro View Post
Image says it all:
I'm not sure the image does say it all. If this is architecture is derived from something AWD like a subaru, the engine supplies power to the front and rear differentials through a third open differential (drawing on left). For example, if you just took the central driveshaft off, you end up with a freewheeling flange (for the rear diff) and the front wheels wouldn't get any power.
If you put an electric motor on the open flange (drawing on right), you'd be pushing power from the motor through the centr diff. you'd have to have the ICE and electric motor delivering torque at the same time in order for the car to move. If the motor was delivering more torque than the ICE, I think it might actually turn the ICE backwards.
If you welded the center diff, it might work as you envision.
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 04-20-2008, 02:08 PM   #5 (permalink)
Green Rodder
Grease Beast - '92 D250 Standard
Econo-Beater DX - '92 Corolla DX
Didn't the high school kids in Philadelphia build a car similar to that?
Old 04-20-2008, 02:13 PM   #6 (permalink)
when?
Malibu Hybrid bennelson Hybrids 17 12-21-2011 10:57 PM
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 36 04-01-2009 03:48 PM
Hybrid buses save NYC money SVOboy Hybrids 2 02-10-2008 04:02 PM
Click and Clack puzzler: SUV or Hybrid? A Familial, MPG Conundrum! MetroMPG General Efficiency Discussion 0 12-20-2007 01:09 PM
GM's Tahoe SUV hybrid ad claims better MPG than Camry* MetroMPG Hybrids 4 12-19-2007 11:47 PM
