Old 03-15-2010, 07:51 AM   #1 (permalink)
Emily - '05 Swift
90 day: 41.87 mpg (US)
Converting to E85
Hey guys,
So i'm currently in my university's motorsport team and we're converting a CBR600RR Engine to use E85 for the Formula SAE competition for 2010. I'm on the fuel system and i'm just wondering about any insight, help or sites/companies where i can find fuel filters, pumps and regulators for E85 would be much appreciated.
I'm not exactly sure about the flow rates we need, my powertrain team leader did some calculations but he's not 100% sure and he feels its a bit iffy, but what he calculated was around 9.06g/s or around 30L/hour.
Anyway i hope you guys can help me in my endeavour
Old 03-15-2010, 09:57 AM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...start by looking at A/F-ratio requirements for 100% ethanol.
...the addition of 15% "real" dino-juice gasoline is the proverbial "...drop in the bucket..." because it's main purpose is for easier cold-weather starting.
...also, which OEM car manufacturer is your program associated with? Ask them what the "mapping" is for E85 at wide-open-throttle (ie: racing) that should pretty much answer your question.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 03-25-2010, 05:08 PM   #3 (permalink)
Ethanol Fan
Mr. Fox - '91 Mustang GT
90 day: 15.99 mpg (US)
CBR600RR, is that a bike? So it's carbed right? Good luck with finding off the shelf parts, more than likely you'll just have to cherry pick. Avoid steel parts, lines, tanks without coating and choose plastic/polymer/synthetic material for parts exposed to fuel. Plastics don't conduct electricity and they don't corrode like steel so they'll last much longer in an ethanol fueled vehicle.
The Stoich A/F values for E85 is approx 9:1 you can expect around 42% increased requirement for fuel under similar Lambda values. For WOT you can enrichen the mix further than gasoline but similar ratios just uprated 42% more fuel is what I'd call safe.
We don't use L/hr we use cc for Imports and lb/hr for Domestics. so I can only guess that you're thinking about 52lbs/hr.
~Allch Chcar
Old 03-25-2010, 08:15 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
LoL besides replacing non-ethanol compatible plastic and rubber all that is needed is either an air restriction (choke) or a larger jet or both.
Playing with jets will get you there.
Check out e85forum.com many there have done what you want on different motors.
E85 - Anyone else getting great results? Rower4VT EcoModding Central 38 05-18-2011 01:10 PM
[Article] Better Fuel Economy with Ethanol? SVOboy General Efficiency Discussion 62 04-02-2010 11:31 AM
EV World's Bill Moore drops the ball trading Honda Insight for 12 mpg E85 truck MetroMPG Fossil Fuel Free 10 12-20-2009 04:01 PM
GREEN CAR JOURNAL, Spring 2009 article (GAS vs. E85 MPG ratings) Old Tele man General Efficiency Discussion 9 10-19-2009 01:03 PM
jetta flexfuel convertion to E85 jetta2.5L Fossil Fuel Free 2 05-20-2009 04:27 AM
