Go Back   EcoModder Forum > EcoModding > EcoModder Blog Discussion
Old 01-01-2017, 08:34 PM   #11 (permalink)
I'm a big fan of Jason Torchinsky, but I'd prefer the Crosley Farm-O-Road:
This one does look cool. Eventually wouldn't be so hard to build a replica with a modern 250cc motorcycle engine...
Old 01-01-2017, 11:03 PM   #12 (permalink)
The EMPI Imp construction details are available as measured drawings. It's only two wheel drive; but with an 80" wheelbase, Type II portal axles, a cutting brake and an hydraulic system it would make a passable tractor.
Edit: Here's a Type 181 clone in aluminum:
and as a bonus, here the VW Pingo from Uruguay:
http://jalopnik.com/this-is-the-last-weird-air-cooled-volkswagen-you-never-1790630292
It's a Jason Torchinsky post so we are back on topic.
Old 01-02-2017, 08:11 PM   #13 (permalink)
By "cutting brake" you mean one that can be applied individually to each rear wheel in order to emulate a traction control? I do remember seeing that in some tractors, but for a road-legal ride I'd rather do something similar to what those Gurgel mini SUVs used, with two levers beside the parking brake, each connected to the parking brake cable of a rear wheel to provide selective braking and overcome slip.
Old 01-03-2017, 02:32 AM   #14 (permalink)
Yes.
SINGLE HANDLE TURNING BRAKE, With Upright Handle, Dunebuggy & VW | eBay
Here's a single handle brake. Forward for right and back for left (or vice versa). The tractor I drove had individual left and right brakes and a toggle that you could flip over to gang them together.
Old 01-12-2017, 10:21 PM   #15 (permalink)
I remember having seen this feature in some tractors too.
