~78% of the energy from the fuel is lost as heat. It takes 8.34 BTU to heat one gallon 1 degree. Start @ 40 f, end at 130 f, ~750 BTU per gallon for domestic hot water.
750 x 50 = 37,500 BTU
Hmm, could you heat your house water on the way home from work, if you had good enough heat exchangers?
1996 Dodge 2500 Cummins Turbodiesel
Custom cab, auto, 3.55 gears
