Old 11-12-2009, 08:16 PM   #1 (permalink)
darcane's Avatar
Silverado - '03 Silverado W/T
Pickups
90 day: 18.7 mpg (US)
Ninja 650R - '06 Ninja 650R
90 day: 52.02 mpg (US)
Coroplast durability
For those of you with Coroplast grill blocks and belly pans... how long does it last?
I'm thinking of doing a few aeromods, but I don't want them falling apart after a couple years. I can't see Coroplast holding up too well in constant vibration, dust, dirt, wind, etc.
-Mike
2003 Silverado:
Aero Mods
Old 11-12-2009, 09:51 PM   #2 (permalink)
2 years and counting now.
The Following User Says Thank You to tjts1 For This Useful Post:
darcane (11-14-2009)
Old 11-12-2009, 11:36 PM   #3 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
How long does your oil last? Tires? Belts? If it works, and it's cheap, just think of it as one more thing that you have to replace once in awhile.
Just don't ask the guys at Jiffy Lube to do it...
Old 11-13-2009, 12:18 AM   #4 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
I've never had it fail in normal service. I used it for a sign once where it bent a lot with every gust of wind, and it lasted two years, failing just along the crease. Once, I built a whole velomobile body from carefully reinforced light-gauge Coroplast. It was only 15 lbs for a rather large shell, as these things go. I planned it to fail gradually, and separate into parts that could be re-glued. The customer rolled it into a grassy ditch with no damage at all. A folded edge will often be more rugged than a frame and fasteners.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Old 11-13-2009, 10:04 AM   #5 (permalink)
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
The paint came off in some spots on my grill block (to be expected) but the grill block is still going strong after three years. The under pan is still going strong after three years as well. All this in MN weather as well. So Coroplast will last!
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
The Following User Says Thank You to TomO For This Useful Post:
Old 11-14-2009, 01:14 AM   #6 (permalink)
darcane's Avatar
Pickups
OK, sounds good to me.
I took the plunge and bought three 4x8 sheets of black coroplast today. $16 ea.
woot!
Mike
2003 Silverado:
Aero Mods
Old 11-14-2009, 01:53 AM   #7 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I plan on using Coroplast for the body panels on my reverse trike project, if I ever get to it.
It's much lighter/cheaper/easier to work with than aluminum sheet or body metal, and I can probably get most of it recycled, as opposed to body/aluminum sheet.
The only place I'll use actual metal is if I need the rigidity, like the nose cone, trunk boxes, etc.
Good Coroplast to Coroplast Adhesive? garys_1k DIY / How-to 18 08-07-2010 04:48 PM
THE Best Coroplast For Flat Underbody Panels! Blue Bomber Aerodynamics 17 04-16-2009 04:53 PM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 12:27 PM
How to get coroplast home? Sean T. EcoModding Central 22 12-09-2008 12:00 AM
Tips for working with plastic, Coroplast, polycarbonate orange4boy Aerodynamics 0 08-30-2008 04:15 PM
