Old 10-27-2009, 05:41 PM   #1 (permalink)
Stickers - '91 Tempo GL
Send a message via AIM to Hermie Send a message via MSN to Hermie Send a message via Yahoo to Hermie
Coroplast- Flexibility?
Like my other thread, I'm looking for good material to use for an air dam/belly pan.
Does coroplast bend well, or does it fold and kink when bent? For example, could I get a 90 degree bend with a 1-2 inch radius without it kinking?
Old 10-27-2009, 08:04 PM   #2 (permalink)
chuckm's Avatar
Exploder - '02 Explorer xlt
Rolla - '02 Corolla ce
90 day: 44.43 mpg (US)
Coroplast will kink on that tight a radius. I don't know if you can heat form it or not. You might consider using sheet metal in those tight bend areas.
"Jesus didn't bring 'Natty Lite' to the party. He brought the good stuff."
Old 10-27-2009, 08:27 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Coroplast is a great material to use overall. It's easier to work with than sheet metal, and it's cheap.
I'd say the minimum radius of curvature is a foot or two. But so what if it kinks? If the kink has a radius of curvature of 0.5", that's aerodynamically similar to what you're proposing.
Have fun modding.
Good Coroplast to Coroplast Adhesive? garys_1k DIY / How-to 18 08-07-2010 04:48 PM
THE Best Coroplast For Flat Underbody Panels! Blue Bomber Aerodynamics 17 04-16-2009 04:53 PM
Coroplast undertray question (covering the control arms) Otto Aerodynamics 8 03-30-2009 12:27 PM
How to get coroplast home? Sean T. EcoModding Central 22 12-09-2008 12:00 AM
Tips for working with plastic, Coroplast, polycarbonate orange4boy Aerodynamics 0 08-30-2008 04:15 PM
