Right now the pwm duty has a resolution of 512, but the accuracy is only maybe 7 or 8 bits. I'm planning on increasing the accuracy (since there's now time because there are no while(); stuff during A/D conversions. So, if the resolution is greater than 8 bits, will that be a problem with the software that's assuming 8 bits? Or will there be a conversion to 8 bit, or should I cut it out with the 9 bit resolution stuff?
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
