Old 10-25-2010, 11:04 PM   #11 (permalink)
Thalass,
I want to do a bike, mostly because I can't afford to do a car... I have a golf cart motor that is decent enough to run at 96v that will get me going plenty fast on a bike...
I assumed my implementation would involve using the gas tank as the heat sink, or at least put my controller's power section up there and try to make it 'resemble' something similar to what the gas tank used to look like. I thought it would be cool to cut and weld hinges on the tank so it could unfold to work on the contoller.. just a thought.
There is a surface mount version of the control board in the works if space is super tight, and Jack's IGBT suggestion will save some space.
Old 10-26-2010, 02:29 AM   #12 (permalink)
jackbauer's Avatar
My next controller build will be for my bike project.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
www.evcbr.com
Electric Motorcycle conversion bennelson Fossil Fuel Free 301 05-25-2012 08:08 AM
Golf cart based electric motorcycle build. Ryland Fossil Fuel Free 49 01-08-2012 01:10 AM
Range-extender Sidecar for EV motorcycle bennelson Fossil Fuel Free 50 05-25-2009 02:21 AM
What would you look for in an electric motorcycle kit? Ryland Fossil Fuel Free 3 05-07-2009 04:42 PM
Extreme Electric Motorcycle conversion for Publicity/Charity - in Motorcycle forum! bennelson Fossil Fuel Free 0 11-17-2008 06:07 PM
