Old 10-19-2009, 10:02 PM   #21 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I was going to mention that the spoiler's line ends up shallower than the side spats, but I wasn't sure in that case it would have been true or not, as there have been cases where the spoiler's surface is actually just folded down to make the side spats on certain vehicles and for certain effects.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 10-19-2009, 10:11 PM   #22 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
Christ and Frank -
I had the same suspicion, but I was too lazy to go looking for the proof.
From Frank's top view picture, do you think the side spats "taper in"? That would also follow the teardrop analogy, at least from my POV.
CarloSW2
American Solar Energy Society
Old 10-19-2009, 10:24 PM   #23 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
It is definitely boat-tailed.
I was thinking of starting a new thread on this and probably should have. Split it off?
I've always seen this style of spoiler NOT boat-tailed. The Fusion is the first one I've noticed with that feature.
Also I've noticed sometimes the "end plates" are flush with the sides of the car and sometimes they are set in.
Set in from sides and boat-tailed
Flush with sides and no boat-tailing.
Set in from sides and no boat-tailing
Old 10-19-2009, 10:57 PM   #24 (permalink)
Carlos -
It would appear that they follow the relative taper of the rear body work, but nothing more. To that extent, yes, they taper. I doubt, however, that it's anything close to an "ideal" angle for flow.
Frank -
A good many of those designs, the intent of the sides seems mostly to be solely to support/add rigidity to the top. It's as if they're not even concerned with side flow, but only believe that flow occurs top and bottom?!
Old 10-19-2009, 11:00 PM   #25 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Of all the examples I put up, I'd trust the aero development on the Fusion the most. It's been in the wind tunnel; who knows about the other guys.
Old 10-19-2009, 11:05 PM   #26 (permalink)
The "other guys" appear to be using a pretty standard design that is widely used to reduce lift, and nothing more, really. See NHRA racing. That's why I mentioned the structural capacity of the side panels, because I believe that's the only reason they're really there.
Old 10-19-2009, 11:11 PM   #27 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Structure is likely most of it and the inset from the sides ones would be in the wake zone anyway- under the "shelf" anyway.
The end plates on some designs protude above the upper surface too. I wonder about the aero behavior of that, straight back vs. boat-tailed... and of course, the behavior of each in YAW!!!
Old 10-19-2009, 11:15 PM   #28 (permalink)
I wouldn't venture to postulate on the effects of shape induced aerodynamics in either of those profiles... that would require extensive testing, afaic.
Old 10-20-2009, 01:16 AM   #29 (permalink)
If that were the case, they'd be reducing front end traction, creating instablity
Old 10-20-2009, 05:30 AM   #30 (permalink)
Pokémoderator
cfg83's Avatar
Christ and Frank -
Carlos -
Frank -
I agree that the Fusion might be extending the rear of the trunk, hence the side spats being "interior" to the tail-lights. I keep thinking the dual-purpose of the spoiler is to "hide" the parachute from the airstream.
Time to DIY :
1975 Chevy Laguna Gets A Racing Spoiler- Popular Hot Rodding Magazine
(and the angle is ADJUSTABLE, too!)
CarloSW2
Morelli Shape Jim Bullis Aerodynamics 184 10-06-2011 07:52 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-31-2010 12:21 AM
Video: clever, simple demo of teardrop shape -pointy end first vs. blunt end first MetroMPG Aerodynamics 10 03-12-2009 09:48 PM
Help me decide the shape of my grille block openings! Tango Charlie EcoModding Central 1 11-16-2008 05:00 AM
Strange OEM Aerodynamic Shape (longitudinal roof indents) LostCause Aerodynamics 17 03-20-2008 12:26 AM
