Old 06-03-2008, 09:40 PM   #11 (permalink)
Whoop's Wheels - '89 Civic Wagovan
90 day: 39.09 mpg (US)
If you have not purchased a air wrench, here is what I have done on my 89 Honda.
I removed the cover to the flywheel. Get a hardened metric bolt in the thread that is used on the clutch pressure place. Put the bolt in from the pan side. It will thread in about 4-5 threads. Rotate the engine until this bolt is up against the transmission housing. Get a 3' piece of pipe and stand on it.
I purchased a 1/2 inch, 18 inch breaker bar and several extensions to get it beyond the edge of the fender. Otherwise I could not get enough torque on it to get it to come loose.
I reverse everything to put it back on, but I only use about a 1 1/2 feet on the pipe extension and pull it as tight as I can.
Best of Luck to you.
Old 06-04-2008, 12:25 AM   #12 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Got it with a 1/2" breaker bar. Bent the hell out of my screwdriver, but the thing finally came off.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 06-04-2008, 04:22 AM   #13 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
yup breaker bar & cheater pipe only thing thats worked for me. my 12gallon compressor and impact gun did NOTHING to budge it. the toughest thing is to secure the flywheel BEFORE using that breaker-bar. PB blaster/wd-40 soak it first a few times also.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 06-27-2008, 05:45 PM   #14 (permalink)
the hicks - '97 Civic HX
caravan - '99 Grand Caravan ES
For next time...You can buy a crank pulley holding tool for about $15 for the Hondas. There are two varieties depending on year. For my 97 civic hx its a 50mm hex thing that you can attach a 1/2" ratchet to. My 1/2" air impact would not remove the crank pulley either, had to use the breaker bar. The other variety has pins that fit into the crank pulley.
Old 06-27-2008, 06:11 PM   #15 (permalink)
ttoyoda's Avatar
I just put the car in 5th gear and have someone step on the brakes. Crank pully does not move.
Old 06-27-2008, 06:12 PM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
1/2" air gun at the shop took mine right off.
Old 06-27-2008, 07:01 PM   #17 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Id be leery of doing it that way. Youd probably be putting more ft lbs through the engine/tranny than what its rated for. Just my opinion anyway.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-27-2008, 07:40 PM   #18 (permalink)
ttoyoda's Avatar
I had the same feeling at first. Then I figured that any shaft in the tranny, and the halfshafts, was much, much thicker than the 1/2 inch drive extension I was using, so my conclusion was that the tranny was stronger than my 1/2 inch extension. I could still be wrong, though.
Muffler removal DifferentPointofView EcoModding Central 31 06-16-2008 10:39 AM
CVCC crankshaft s2man Off-Topic Tech 6 03-03-2008 12:19 PM
