Old 08-15-2008, 05:45 PM   #1 (permalink)
Deals Hunter
Red "Vicks" - '93 Civic VX
90 day: 52.23 mpg (US)
Crapped. 2 tires have bubbles.
Was taking pictures of my car today and found out that the 2 rear tires have bubble on the sides/edge of the tires.
Tires are: Toyo 800 Ultra Premium. Tires were purchased in 1998 with 45K on the odometer. Now it's 84K and the tires still have alot of treads left on them.
Guess I'll just buy 2 replacement and put those on the fronts and the other 2 Toyo in the rears. Any specific tires to get? Current size is 175/70/13. Or should I just replace all 4 tires with stock size and keep the other 2 as spares?
Honda Civic VX Video Review
Old 08-15-2008, 05:55 PM   #2 (permalink)
Taurus SEX - '01 Taurus SEX
Personally, I wouldn't trust a tire over 5 or 6 years old. They wear quicker and are more prone to blowouts at the older age.
Old 08-15-2008, 06:25 PM   #3 (permalink)
Interested Newbie
Katana's Avatar
Silver Citroen Saxo - '02 Saxo 1.4i Furio
Yes get replacement ones. My father does MOT tests (British government road worthiness test) for a living and having bubbles or bulges on the tires would be cause to fail the car, as i learned when he found some while checking over my car a while back. Something about how the bubble is equivalent to a hernia would be on a person, to paraphrase him.
Basically if it looks dodgy get a new tires since you don't want to mess around not getting something as important as them.
Crooked toothed, tea swilling crumpet eater!
Old 08-15-2008, 06:36 PM   #4 (permalink)
TrikeKid's Avatar
The ClownCar - '91 Metro Base
Send a message via AIM to TrikeKid Send a message via Yahoo to TrikeKid
Unless the tire has real damage like in the case of sidewall "bubbles" (sounds more like a broken belt/cord if I'm visualizing it correctly) and it isn't worn out, there really isn't a need to replace it. I've seen some pretty scary looking tires (from a dry rot perspective) make it till they wore out. I wouldn't have driven on them, but the owners did just fine. I wouldn't fiddle around with running tires with busted cords like that, replace them. Tiny tires like that are far cheaper than totaling your car when one blows out.
Old 08-15-2008, 06:45 PM   #5 (permalink)
Hyundai Accent - '01 Accent
90 day: 38.4 mpg (US)
Gixer - '97 GSXR600
90 day: 43.12 mpg (US)
I don't know if you should replace them or not, but if you get two new ones, they go on the rear and the old ones should go up front.
Old 08-15-2008, 07:10 PM   #6 (permalink)
Silver EP3 - '02 Civic Si
1998? they do go bad with age.....
Old 08-15-2008, 07:11 PM   #7 (permalink)
Deals Hunter
Well I need to find a new set asap because tomorrow is the start of "No-Tax" weekend.
Old 08-15-2008, 07:12 PM   #8 (permalink)
Um, personally I would put the carp times on the rear....
Old 08-15-2008, 07:34 PM   #9 (permalink)
Gixer - '97 GSXR600
Nope, I just found this out when my friend had to get two new tires, the shop put them on the rear.
It turns out that it is much easier to regain control if your front end slides out than if the rear end does. Also, in a panic situation, most people's instinct is to brake, which puts more weight and thus more traction on the front tires. So the new tires always go on the rear.
Old 08-15-2008, 07:45 PM   #10 (permalink)
Deals Hunter
No shops around have any 165/70/13 in stock! They are all special order one. Sears quoted me 175/70/13 Sumitomo HTR for $350, includes installation. While I can get the 165/70/13 from tirerack for $41 each. $200 shipped.
Or should I up the size to 175/70/13 and stick with those? There are more options and cheaper prices.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 10:13 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 38 04-13-2011 07:12 AM
Video: Can Skinnier Tires Increase Fuel Economy? Peakster EcoModding Central 62 03-12-2011 03:58 PM
How about these tires for my car EP3 EcoModding Central 2 06-24-2008 03:37 PM
FS: Set of (5) VX Rims with LRR Tires XFi For Sale 2 02-16-2008 03:49 PM
