Old 06-27-2008, 05:19 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Crashing is real bad for fuel economy
So take my advice and always tighten your lugs!
In unrelated news I fixed that clunking on my car,
Old 06-27-2008, 05:48 PM   #2 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
Foci - '03 Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
The AXe - SOLD - '97 Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
So what have you crashed then???
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 06-27-2008, 06:09 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
I've only personally crashed a bike, . But would've been close had a gone for a longer drive on the half-on lugs
Old 06-27-2008, 07:30 PM   #4 (permalink)
AXMonster's Avatar
I did this in my Supra, left one back wheel on just finger tight after changing the brake pads. A few days later I took a friend for a spin on a private road up to 'a lot' of mph.... then noticed a knocking noise the next day. That back wheel had started working its way loose
I was lucky LOL
Old 06-27-2008, 07:42 PM   #5 (permalink)
adam728's Avatar
97 LeSabre - '97 LeSabre Limited
90 day: 26.95 mpg (US)
I too have done this, but was too stupid to find it.
Did brakes on my old 85 Toyota pickup. A few days later the backend was clunking badly as I pulled into the apartments. I knew the pinion bearing was on it's way out, and assumed the noise was teeth being sheared off the ring/pinion.
Didn't drive it for 3 weeks while searching for a center section I could afford. Spent the better part of 2 hours digging a parts truck out of the snow that a buddy had (sat behind the barn, snow was drifted about 9-10 feet deep over it, made a little tunnel to the rear end).
Later on I found out the front wheel had come loose, and the horrible knocking/jerking was the cast ribs on the back of the wheel smacking the caliper.
Stupid stupid STUPID!
But hey, we all make mistakes....
Miles displaced by bike in 2008 - approx 68
Miles added to vehicle by driving to rides with buddies - way more than above
Old 06-27-2008, 08:06 PM   #6 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Add me to the list too. I actually took off work on a Friday to fix my CV joint (or what I thought was a CV) because I was going on a trip that afternoon. Turns out I just had to tighten up the lugs. It was a happy time.
Old 06-27-2008, 08:41 PM   #7 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Yikes! That would've sucked! I once saw what happened when a car lost a wheel and hit another vehicle head-on.
Later, the accident investigators reported only one lug nut held the wheel on and it sheared off after driving a few miles. Turned out to be an attempted murder case (those other 3 lug nuts didn't magically unfasten)...
Good thing you checked it. Glad you're OK!!!
Maybe everyone should go out and give them a quick torque. I shall declare it "Lug Nut Torque Awareness Day"
-Rick
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 06-27-2008, 11:22 PM   #8 (permalink)
penny pincher
kevlar's Avatar
lucky - '92 pickup plain
90 day: 32.08 mpg (US)
Lug nut sins
Forgive me fathers for I too, have committed this sin.
I once had a minivan on stands with a 4 wheel removal project, put the wheels on thinking I would remember to tighten them up after dropping it down, then forgot after dropping it. I drove it to work the next day for testing, then realized it was awful wobbly after about 20 miles. I pulled over to find almost every wheel was not tightened and ready to fall off
Every dollar I save, .....I save!
half exposed Lucky http://ecomodder.com/forum/attachmen...1&d=1210727433
how it was done...
http://ecomodder.com/forum/showthrea...html#post25264
as of feb. 09, still holding up great with new owner,
who has since re-geared the rear end and gets nearly 40 MPG!
Old 06-28-2008, 10:05 AM   #9 (permalink)
adam728's Avatar
This all reminds me of Ron White's bit against Sears.
"Apparently their mechanic was absent on lug nut day..."
Old 06-28-2008, 10:50 AM   #10 (permalink)
NewBlue - '07 Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ranger XLT
90 day: 25.84 mpg (US)
I was in Chautauqua County, NY riding with the PD out there for work when we went by a call they had just gotten, the tire came off a car, bounced at the side of the road and went through a picture window in a VFW building. Luckily nobody was hurt in the instance but lug nut awareness is important!
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Fuel Economy related papers tasdrouille General Efficiency Discussion 31 01-18-2011 11:48 AM
Lugging the engine - good or bad for economy? landspeed General Efficiency Discussion 27 06-22-2008 09:47 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 01:42 AM
