Old 03-25-2010, 01:29 PM   #1 (permalink)
The Crimson Crawler - '04 Elantra GLS
90 day: 36.71 mpg (US)
Crimson Crawler got grill block
So the other morning, probably a week or two ago, I made my first ecomod on the new car. Using some leftover LDPE foam from packages at work, I made a grille block!
I'm noticing improved warmup times; between .75 and 1.5 miles shorter.
It's similar to pipe insulation foam. Not quite the same stuff, but it was available, free, and it's really easy to work with. a couple quick slices with a pocket knife and about 10 minutes.
Now, to start on the coroplast underbelly. I have one 2x4 foot piece of white at home to start with...
Old 03-25-2010, 02:27 PM   #2 (permalink)
My Goal: 35 MPG All City
RandomFact314's Avatar
The Neon - '00 Neon
90 day: 25.38 mpg (US)
G/F's Car - Kyan - '01 Rio
90 day: 23.94 mpg (US)
The Accord - '97 Accord LX
90 day: 22.41 mpg (US)
Lizzy (all city) - '88 CRX Si
House of Tudor
90 day: 31.92 mpg (US)
That's defiantly the first foam one iv ever seen
I would just be scared of the foam melting or something if it got real hot in the engine bay, my coroplast one warped just a little from the hot engine temps (and hot days I guess)
Old 03-25-2010, 02:33 PM   #3 (permalink)
The space between the grille and the rad is between 6 and 8 inches; I hadn't thought of that. Thanks though - I'll be sure to check on it. I've heard of other people using pipe insulation foam, or buying a pair of flip-flops and cutting them into strips that fit in between the grille bars.
Old 03-25-2010, 02:42 PM   #4 (permalink)
The Neon - '00 Neon
House of Tudor
Never thought about using flip flops, that might be a pretty good idea...
I want to use plexy glass how mine is now so you can see through it and it look 1/2 normal looking
Old 03-25-2010, 05:00 PM   #5 (permalink)
robbiewt's Avatar
Yaris? - '08 Yaris LB
90 day: 44.32 mpg (US)
Send a message via AIM to robbiewt
I had a 2001 Elantra GLS. Back then the upper grill was part of the hood, and was held on with four screws. This allowed me to completely remove the grill to make my block.
Here is what my block looked like when it was done.
Old 03-29-2010, 01:23 PM   #6 (permalink)
I just bought a GT, a month after you bought your GLS. Mine had 86,000 miles on it, with a manual transmission. Good to know that you have the same year Hyunda Elantra, though not exactly the same model!
I curious -- what do you see for engine temps with your grille block? My Elantra already goes just above the center level on the heat gauge, driving in 50 degree F temps. I need to see if my cooling system is working 100% before I try anything with the grille.
2004 Hyundai Elantra GT Hatchback bought 3/9/10
3/10/10--27.5 MPG on a 19 mile ride r/t through the burbs
3/14/10--32MPG hwy, 30mi test after new spark plugs
3/22/10--35MPG hwy after new Michelin Primacy MXV4 tires
3/28/10--38MPG, 80mi test most hwy using hypermiling
Old 03-29-2010, 02:05 PM   #7 (permalink)
well, I've NEVER had the fan come on in my car, even with the grille blocked at temps of up to 75 F. Max water temp I've recorded was 192 F on the ScanGauge. My needle at max temp is about 1 "needle's-width" below the white line in the midde of my gauge. I don't know if you have the same size temp gauge as me or not. Mine doesn't even begin to MOVE until 150 F. The first "quarter" mark is about 175, and I think the middle mark would be 200 if it ever got there.
Old 03-29-2010, 03:32 PM   #8 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
I think it's perfect. If you do get a little warm, once summer comes, you can easily pop it out piece by piece until it's again perfect. I'd go ahead and block the top slot to see how it performs.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 03-29-2010, 04:45 PM   #9 (permalink)
The problem with blocking the top one is that the upper portion of the "grille" (the top chrome line) is actually the hood. So every time I open the hood the very upper line would fall out. I haven't figured out a good way to take care of it, but I shall.
Old 03-29-2010, 05:54 PM   #10 (permalink)
O I C. Hmmm....
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Tacoma Grill Block mjboks Aerodynamics 6 01-11-2010 09:44 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
