Old 01-31-2010, 07:10 AM   #11 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Say you're going 60 mph and you're getting a 60 mph crosswind at 90 degrees. What I called the flow vector is going to be 45 degrees.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-31-2010, 03:12 PM   #12 (permalink)
puddleglum's Avatar
Rondo - '07 Rondo EX
90 day: 25.5 mpg (US)
Originally Posted by BamZipPow View Post
Fixed yer links...
Thanks. What did I do wrong?
Old 01-31-2010, 09:13 PM   #13 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
I think you clicked on the "Insert Link" button and when you pasted yer link, you had copied the "http://" part which the link button already added in.
Old 02-01-2010, 02:07 PM   #14 (permalink)
wind: EPA & SAE
EPA published a chart in 1970s.
An 18-mph crosswind reduces mpg by 2%.
From Bain Dayman,Jr.,Jet Propulsion Lab,Cal Tech Univ.,SAE Paper 780337:
Annual mean wind spectra effect on zero-yaw Cd
Annual Mean Wind Speed,mph
5.8 10 15
Highway + 4.5% +12.0% +33.0%
This is not targeted specifically to crosswind,but will give you a feel to effect on Cd.
With respect to skirts,I've never come across any research which suggested that a skirt should be any lower than the bottom of the floorboard.
For a ground-effect racing car there would be a very carefully designed intake at front,then the rest of the car would be sealed all the way around until the very rear,where the low-pressure wake could communicate under the car, inducing downforce.
moonmonkey (02-01-2010)
Old 02-01-2010, 10:36 PM   #15 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.91 mpg (US)
then its front and rear strakes aka tire boattails. instead for me,, the rocker panels are even with my belly pan already.
Old 02-02-2010, 06:57 PM   #16 (permalink)
strakes/boattails
Yes,the leading and trailing fairings really help for the wheel drag.
Ford found that a trailing fairing after the front tires was not necessary on it's Probe-IV.The MG EX-181,Sunraycer,and Honda Dream-2 all employed complete fore and aft fairings for their tires.GM did delete theirs' for the trans-Australian Solar Challenge so they could survive 40-mph crosswinds,a strategy which allowed them to out run storms and get to sunshine.
Old 02-14-2010, 11:51 PM   #17 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
I have Hucho's "bible" here with some data on side skirts and yaw in semi trailers and they improve the CD. At a yaw of 25˚ the cd is .15 better with fully skirted wheels.
CD @ 25˚ yaw faired: 1.0
CD @ 25˚yaw open wheeled: 1.15
Amen.
The Following User Says Thank You to orange4boy For This Useful Post:
aerohead (02-15-2010)
aerodynamics, drag, frontal area, side skirts
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 136 04-15-2012 04:32 PM
BMW cooling duct fabrio. Aerodynamics 19 09-27-2008 04:48 PM
