Old 01-30-2010, 12:47 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Question Cross wind drag and side skirts / 'tails
A few years ago, I added side skirts to my Civic.
I removed them since they add several feet of frontal area to the car when hit by a crosswind. *
What kind of FE hit does a car get from increased side frontal area ?
On a similar thought, what about boattails and the increase in frontal area that they produce ?
* Where I live ( the 'hill country' ) , there is a lot of wind that blows in from the sides of the car.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
Old 01-30-2010, 12:50 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I wonder how crosswinds affect semis regarding FE.
I know that the semi becomes less stable, but is there also a big FE hit ?
Old 01-30-2010, 02:35 PM   #3 (permalink)
skirts/tails
Skirts should not project below the "bottom" of the vehicle and consequently should not aggravate it's side area.
I can't answer the question about drag vs increased side area.I've never seen anything published on it.There is a table published by EPA on wind/mpg effects.
One benefit of skirts in crosswind,is that they help cancel roll moments above the C.G.,actually increasing stability and safety to an 18-wheeler.
I've only run "short" tails,so I can only address those,and my experience so far is that they offer no degradation of stability,thanks to Professor Morelli's work at Pininfarina.
Old 01-30-2010, 02:42 PM   #4 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
I can only imagine underside airflow at a yaw angle is extremely complex. I don't think side skirts have a negative impact on drag even in crosswinds. Remember, the flow vector is very rarely gonna be perpendicular.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 01-30-2010, 03:19 PM   #5 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Talking
Got any piccies of yer vehicle with the side skirts on?
Old 01-30-2010, 09:44 PM   #6 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I knew that was coming ...............I'll have to find them.
( Not sure if I deleted them. )
EDIT : I found this picture, but it has some quick and sloppy Photoshop work . The skirts and wheel gap filler are real, but the diffuser thingee etc are Photoshop additions.
Phil : When you say that the skirts shouldn't project below the 'bottom' of your vehicle, what do you mean ? Do you mean the floorboard ??
( surely not )
Tas : Can you simplify what you said about 'flow vectors' going perpendicular ?
( Imagine that you are trying to explain what you just said to someone with the mental capacity of a child ...... or a very smart monkey . )
Old 01-30-2010, 10:47 PM   #7 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
Well, if you get a crosswind on a sailboat, and increase the sail area, it goes faster. Most of the rigid-wing sailing cars have not had a way to adjust for right or left crosswinds. I saw Mana La get hit by a gust, and the acceleration was obvious. Second Inning: Mana La Solar Car Put On Display At Peterson Automotive Museum - Green Diary YMMV
The Following User Says Thank You to Bicycle Bob For This Useful Post:
Cd (01-31-2010)
Old 01-30-2010, 10:50 PM   #8 (permalink)
BamZipPow's Avatar
I'll show you mine...
The Following User Says Thank You to BamZipPow For This Useful Post:
Cd (01-31-2010)
Old 01-30-2010, 10:59 PM   #9 (permalink)
puddleglum's Avatar
Rondo - '07 Rondo EX
90 day: 25.5 mpg (US)
http://http://www.bentleypublishers....ery-768-8.html
Frank Lee posted this link in response to a question I had on crosswind.
http://http://207.242.75.40/derbtech/windeff.htm
Here is another one that I found. Both have good explanations of crosswind vectors.
The Following 2 Users Say Thank You to puddleglum For This Useful Post:
Cd (01-31-2010), Piwoslaw (01-31-2010)
Old 01-30-2010, 11:03 PM   #10 (permalink)
BamZipPow's Avatar
Originally Posted by puddleglum View Post
Race Car Aerodynamics - Designing for Speed *-* Bentley Publishers - Repair Manuals and Automotive Books
Wind Effects
Fixed yer links...
aerodynamics, drag, frontal area, side skirts
Side mirror drag & effect on fuel economy - quantified MetroMPG Aerodynamics 136 04-15-2012 04:32 PM
BMW cooling duct fabrio. Aerodynamics 19 09-27-2008 04:48 PM
