Old 05-30-2008, 05:19 PM   #1 (permalink)
TDI'er
ArtFox's Avatar
TDI'er - '03 JETTA TDI Wagon
Cruise control hack/modification?
Anybody found a way to modify the parameters for accel/coast on a cruise control? It would be great to devise a +/- 5mph so that hill climbing would gradually decel to your - 5mph setting. Also allowing the car to coast 5mph faster than the setting going downhill...
Old 05-30-2008, 05:22 PM   #2 (permalink)
TDI'er
ArtFox's Avatar
I guess one would have to wire in an inclineometer?
Old 05-30-2008, 08:13 PM   #3 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
I just setup a governing block on the cam that pulls the cruise cable. Essentially, it will pull the throttle setting (in my case, a ~12% throttle limit) up to the set speed, and then on hills, modulate the throttle for the set speed as usual. If the limit is hit on a hill or in strong winds, the load-up/slow-down occurs. It overshoots the setpoint a bit on downhills, but not much. It's still good if you need to focus on other things, or are too fatigued to hypermile.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 06-01-2008, 02:29 AM   #4 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
if the cruise is working off the vss maybe you can do some sort of altering on the feed from the vss to the cruise electronics.
Old 04-14-2009, 02:02 AM   #5 (permalink)
Puerto Rican Hypermiler
jomelmaldonado's Avatar
Toyota Echo - '05 Echo
90 day: 40.81 mpg (US)
Hello, maybe this thread I participated in will help you in something:
Cruise Control (with MPG sensitive logic)
Old 02-15-2010, 04:20 AM   #6 (permalink)
use a electronic level for incline/decline
Old 02-17-2010, 09:57 PM   #7 (permalink)
Use jomelmaldonado's link. You'll learn alot from it. BTW, have you already tried using a n electronic level for incline/decline like shawn advised?
Old 02-18-2010, 06:02 PM   #8 (permalink)
The cruise on my car does this now and it is standard.
Set at 95 Kph it will let the engine return to idle on a downhill run and the speed goes up according to gravity assist until that runs out and the speed gradually slow to 95 again and the engine return to drive the car at about 1750 RPM.
The car is a GM variant locally built: Holden Commodore VY sedan , 3.8 with the 4L60E trans.
Pete.
Cruise Control (with MPG sensitive logic) guitarterry EcoModding Central 136 12-10-2011 09:25 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Aftermarket Cruise Control homeworkhome53 DIY / How-to 19 12-10-2008 08:07 PM
3 ?'s (SuperMID; cruise control for Metro) Pillzilla EcoModding Central 16 03-31-2008 07:34 AM
TP control? Harpo EcoModding Central 9 03-14-2008 07:54 PM
