07-29-2008, 06:17 PM
#11 (permalink)
Hell, I wish I could make my car stay at a desired RPM than a desired speed.
07-29-2008, 07:53 PM
#12 (permalink)
Don't some tractors have a simple 'choke cable' type throttle option? Seems you pull it out and twist it to lock the rpm you want. If you step on the throttle, it mechanically disengages some how. Any sod busters reading this ever seen one?
07-29-2008, 08:53 PM
#13 (permalink)
6 speed Diesel FTW!
Originally Posted by metromizer
JC Whitney used to offer one way back in the early 80's. A friend installed one on his VW bus. As i recall, it was a real simple mechanical device that attached under the accelerator pedal, to the linkage, and had a cable up on the dash. When you tapped the gas pedal, it disengaged I think.
If you come up with one, let me know, I'd be interested, too.
Sounds Perfect; I would like such a device; esp if it would release with the brake as well.
How about a solenoid that locks the cable at X throttle until you release it.
6 speed ALH TDI
07-29-2008, 09:05 PM
#14 (permalink)
Hi-Tech Redneck
If the servo is vacuum operated, why not hook into a vacuum source, run it to the dash with a regulator and simply "dial in" the desired amount of speed?
07-29-2008, 09:15 PM
#15 (permalink)
6 speed Diesel FTW!
You've got An Idea there; but it would dial in the amount of throttle, not speed; PERFECT.
Ofcourse you would have to bypass the control portion of the cruise actuator.
6 speed ALH TDI
07-29-2008, 09:24 PM
#16 (permalink)
Hi-Tech Redneck
You could the hook it to the brake booster with a check valve that would "Turn off" the cruise when applying the brake.
Damn, I'm full of ideas!
07-29-2008, 09:26 PM
#17 (permalink)
6 speed Diesel FTW!
I like; how would that work?
(won't work for my I'm drive by wire)
6 speed ALH TDI
07-29-2008, 10:29 PM
#18 (permalink)
Hi-Tech Redneck
This is a rough draft and the "check valve" may have to be an electric dump valve hooked to the brake switch to work right. Maybe some other members can improve on this idea.
07-29-2008, 11:27 PM
#19 (permalink)
Ecoformance Engineer
EJ7 - '96 civic Hx Last 3: 58.02 mpg (US)
I love the idea of a DIY vacuum actuator system
but here is a $40 electronic throttle lock, disengages cruise by touching the brake
http://www.conrad-anderson.co.uk/cru...rottlelock.htm
they are located in the Uk so i dont know how much shipping would be.
70 mpg or die modding
www.full-race.com
Originally Posted by MetroMPG
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
