Old 04-14-2011, 05:25 AM   #11 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
I used a mechanical fan switch to control a cooling fan for several years (Autozone?). I found that I needed to put the sensing bulb INSIDE the top rad hose near the thermostat to get sensitive switching...using it outside the rad didn't work.
Just used some non-hardening gasket goop where the fine tube went under the top hose and clamped down over it.
The switch I used didn't need a relay...it could handle the amps used by a 1.5 L engine fan.
Also used an indicator light inside.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 38 03-29-2012 04:53 PM
[CRXMPG Mailbag] SuperMID and VSS Issues with EF Civics SVOboy Instrumentation 0 02-03-2008 04:33 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
[CRXMPG FAQ] DIY Push Button Start SVOboy Off-Topic Tech 0 12-06-2007 02:33 AM
