Old 01-05-2010, 05:03 PM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
If your steering is still too "heavy" for you, you can change the steering feel by changing the caster angle of the front wheels, which can be accomplished in several ways using the stock parts, at least by a few degrees.
If you use MC tires on your car, you will have next to no wet traction, a higher RR figure in many cases, and a fairly slide happy front end, assuming you're using a MC tire that's thinner than the OE Metro tire.
There are car tires that are thinner than the Metro's, but you just don't find them that often. Maybe some place like Coker Tire would have them? Some cars came with 10" rims and tires.
You could also get highway-rated trailer tires, but you still end up with higher RR and such.
If you do end up using MC tires on the front, you'll want to adjust the camber setting so that you can use the shoulders of the tire when steering, to make up for the leaning effect that motorcycle tires are designed to accommodate.
That will afford you the highest possibility of not sliding off the road at the first hint of wet or uneven pave.
Old 01-05-2010, 05:22 PM   #12 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
The Citroen 2cv uses 135 X 15. Many odd sizes are available for classics, but few are as efficient.
Old 01-05-2010, 05:47 PM   #13 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Anyone that can build their own tires has earned my respect!
Christ (01-05-2010)
Old 01-05-2010, 07:10 PM   #14 (permalink)
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
Those 135 Citroen tires are only an inch and a half wider than a typical 100 width M/C tire. Heck a 155 section tire is only about 2 inches wider than the same M/C tire.
That being said, 100 width m/c tires made for touring, pumped up to 50 psi would provide a pretty darn narrow contact patch. Probably pretty low friction with the right tire choice. Tire longevity would be less than the car tires, but that's not the point.
For lowest steering effort go with thin small diameter tires and the lowesT vehicle weight possible. The longer contact patch of m/c tires acts like a rudder trying to keep the tire straight. Make sure the steering and suspension attachment points are very rigid. Body flex is a contributor to heavy, vague steering. Little 145x12" Metro doughnuts will do a fine job for what you're after.
Learn and Share your driving and modding skills at the MPG Challenge in Lacey, WA. First Saturday in May!
http://www.ci.lacey.wa.us/city-gover...ve-energy-fair
Old 01-05-2010, 07:46 PM   #15 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
Motorcycle tires are expensive, and wear fast.
I suggest you increase these in size...
Old 01-06-2010, 01:43 PM   #16 (permalink)
Jeep - '04 Liberty
90 day: 19 mpg (US)
Geo - '91 Metro Lsi convertible
90 day: 39.31 mpg (US)
Mazda - '01 MPV LX
90 day: 20.34 mpg (US)
Sounds like you just want to build a custom 3 wheeled vehicle using the Metro as the platform.
In that case, I think all work with motorcycle tires, or anything of that nature, would be completely custom and unless someone on this forum has done so, I don't know if they can be of any real help. The best advice would come from the maker of the car in that photo that you posted.
Trying to make the most of what God has given me.
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 140 11-21-2011 09:13 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
MPG-friendly scooter and motorcycle tires? 1337 Motorcycles / Scooters 7 01-05-2010 09:32 AM
Metro / Firefly 4 x 12" O.E. Rims with Snow Tires (Used 1 Season) flydude1221 For Sale 1 11-14-2008 10:08 AM
geo metro tires gwahir EcoModding Central 0 04-11-2008 12:29 PM
