Old 08-02-2008, 04:42 PM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
CV Carbs
Originally Posted by Coyote X View Post
CVK40
how a cv carb works They are a pain to get performance out of but they are pretty good at mileage.
After thinking about it I think if there was a way to measure slider position that would relate really well to fuel flow for everything except wide open/idle. And for that A good guess would probably be close enough.
I don't know if it would be easier to figure out how to measure the slide position and guess, OR retrofit fuel injection
But for fun, lets consider some strategies for measuring the slide position:
1. a "fish finder" type circuit (needs single digit microsecond accuracy at these distances) above the diaphragm to measure its position.
2. a cds/light source sandwiching a window with a tapered shaded area that moves up and down with the slide.
3. a variable inductor in the diaphragm (liking this one best so far)
Any others? I suppose one could test the fuel flow rate at different slide positions on the bench and build a map from there.
Old 08-03-2008, 07:13 PM   #2 (permalink)
EP3 - '03 Civic Si
90 day: 31.73 mpg (US)
Scooter - '93 Elite 80
90 day: 74.87 mpg (US)
Ape - '07 Sportcity 250ie
90 day: 66.97 mpg (US)
I think most people get a larger jet and exhaust when concerned about performance on cv carbs, don't they? I beleive most scooters use cv and they have a ton of aftermarket jetting kits and exhausts to get more air and fuel through to increase performance(but not economy of course). What kind of vehicle are we talking about here?
Old 09-15-2008, 10:08 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
So I received a map sensor from Coyotes old metro. And was thinking about tapping into the top of the CV carb (above the slide diaphragm, assume I wont interfere with the slide movement) and am having a little bit of trouble theorizing what it will detect if anything.
I want to think that it will be proportional to the needle position, assuming a strong enough signal, because it "looks" like it should work that way. The vacuum compresses the spring. The more the vacuum the higher the needle.
I don't know if it will have enough pressure for good resolution though because it doesn't take much force to compress a cv spring and that diaphragm is pretty large.
Any predictions?
134
CV boots-need mechanical advice please Cd Off-Topic Tech 30 06-30-2008 12:19 AM
