Old 01-31-2010, 12:50 AM   #41 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Lol, well I don't think the cam bit is insurmountable or anything, just wanted to address the dynamic balance issue.
Old 01-31-2010, 12:54 AM   #42 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I see.
I'm sort of wondering about using that 3rd cylinder (if it's just one that's damaged) and using it for steam expansion or something. I just hate to lose a cylinder that could be doing some work, ya know?
Old 01-31-2010, 12:56 AM   #43 (permalink)
dcb
needs more cowbell
dcb's Avatar
I suppose a little quality time wiggling the big ends is in order.
Old 01-31-2010, 01:04 AM   #44 (permalink)
Steve - '92 Festiva
Yup, they could all use a little wiggle.
I just hope it's not a main bearing. If it is, I'll likely have to scrap the idea, because I'm not willing to put any money into that engine.
Old 02-03-2010, 09:57 PM   #45 (permalink)
Betsie - '91 Storm wagonback
Okay 10% would be pretty lame because that's well within the realm of driving technique and you'll only have like 30-40hp. I just figured that's usually what you get with an alternator delete and that seems like a PITA. I think 20% or so should be the minimum for it to be really worth it; especially because I just did my oil pan/pump gaskets today and pulling the pan is no fun, and not even half the battle for you. a 3 cylinder storm would be awesome if you can do it, but if not 2 should do just fine.
Old 02-03-2010, 10:00 PM   #46 (permalink)
Steve - '92 Festiva
Originally Posted by ahab13 View Post
Okay 10% would be pretty lame because that's well within the realm of driving technique and you'll only have like 30-40hp, so you'll probably want at least a 20% return. I just figured that's usually what you get with an alternator delete and that seems like a PITA. That and I just did my oil pan/pump gaskets today and pulling the pan is no fun either. a 3 cylinder storm would be awesome if you can do it, but if not 2 should do just fine.
If I were to do 3, I'd use the 3rd cylinder for an expansion chamber, nothing more. There would be no combustion taking place in there, only hot exhaust gasses entering with water mist, and exhaust gas/steam exiting.
That'll likely be too much BS to handle, so 2 cylinders it is.
Old 02-05-2010, 11:28 AM   #47 (permalink)
amateur mech. engineer
Sporty Accord - '88 Accord LXi
90 day: 23.25 mpg (US)
Dad's Camry - '01 Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Camry
90 day: 37.3 mpg (US)
Hi, I thought it might be useful to add some comments because I've tried using cylinder deactivation in several engines. One was my Accord with a 2 liter 4 cylinder engine. I ran it for about 700 miles on just cylinders 1 and 4. It worked fairly well. It could cruise at 60 MPH in fourth gear, climb most hills without slowing down in third gear and climb a really steep hill (maybe about an 8% grade) in second gear at 50 MPH.
The biggest problem was the vibration when the engine ran less than 2000 RPM. It was damaging the exhaust system. I had to replace the flex pipe and weld the pipe next to one of the hangers after it broke there. I'm not sure it got better fuel economy. It seemed disappointing. I think it was better on the highway and worse in local driving. It might have been running too rich at low engine speeds.
Here are my suggestions for making your engine useful again. Remove the oil pan and disconnect the #1 connecting rod cap. You will probably find a damaged bearing. Examine the crankshaft journal too. If it's rough you can use a long strip of wet fine sandpaper to make it smoother. Clean off the crankshaft and install a new bearing into the connecting rod, oil it and connect the rod back to the crankshaft. Then install the oil pan. This method will preserve the balance of the engine. Then you have to decide whether to use cylinder #1 to make power or deactivate it. If you use it to make power, the new rod bearing might wear out fast if the crankshaft is worn badly.
If you want to use only two cylinders you would deactivate #1 and #4. After you remove the rocker arms for those cylinders you will need to block any exposed oil holes on the rocker shaft. I did that with some small hose clamps. It might be good to put brass shims inside the clamps the if the clamps are not very smooth.
You need to unplug the fuel injectors for the unused cylinders. On my car, there was no need to connect any resistors to the wiring harness. The computer didn't complain. On my car, there are two oxygen sensors so I had to disconnect one and connect the one operational oygen sensor to both cables. My car had almost no power to get moving at first. It improved after I used a restrictor inside the vacuum hose that leads to the MAP sensor. That reduces flucuations of the vacuum. I think it made it run leaner. I used a couple of wires to short out the unused spark plugs. I wasn't sure if the sparks could cause any trouble in the deactivated cylinders.
I like the idea of using deactivated cylinders for extra expansion of the exhaust gasses but I don't think it could be done at a reasonable cost. The expansion cylinders would have to have a different kind of valve control so they would operate on a two stroke cycle. The intake valve would be open while the piston goes down about halfway and then close. The exhaust valve would open when the piston is near the bottom and then close before it gets to the top. It is best if the pressure in the cylinder is the same as the exhaust pressure from the normal cylinders when the intake valve opens.
I found the article about the Mother Earth V8 to V4 conversion. It is on the internet and here is the link: Can you convert a V8 engine to a V4 and save gas?
This plan is a little different because the exaust valves are removed from the deactivated cylinders. That makes cranking easier because it avoids having a compression stroke in two cylinders at a time. I think it probably wastes some power when the engine runs fast.
Potential engine mod? Otto to Atkinson conversion AndrewJ EcoModding Central 78 12-02-2010 07:02 AM
Has anyone done spark plug gap tests? ziddey General Efficiency Discussion 29 06-07-2010 09:59 PM
View from the other side: "Thank you Toyota for NOT giving us cylinder deactivation" MetroMPG The Lounge 9 11-16-2009 11:10 PM
Cylinder deactivation discussion diesel_john EcoModding Central 67 11-05-2009 07:29 PM
Homebrew Cylinder Deactivation elhigh EcoModding Central 1 03-11-2008 03:15 PM
