Old 02-12-2008, 11:05 PM   #21 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Here's the deal...
So, Chevy makes a V-8, front-drive Impala (which I will admit is fast).
People want a HEMI Charger, but they don't want to pay for more fuel.
The answer?
Cylinder Deactivation. LOTS of cake, and eating it until you're sick. Good idea. Poor implementation.
I've driven each of these applications, hooked up the SG, and found minimal advantages: 5% at best. The base engine in both examples have plenty of power and achieve much better FE. The Impala 3.5L pushes 30 mpg with mostly highway driving.
There has to be a paradigm shift in engine size perception. A 4-banger with a turbo is a good solution, but much of America still sees V-8 as "I've made it". That's where the manufacturers are. I wish I could have manually cut the cylinders -- it would have helped in-town driving for sure, but how much? Dunno.
I wish the best to those testing this experiment -- just make sure to perform ample research.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 02-12-2008, 11:29 PM   #22 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
would two smaller engines, in essentially one box, connected by a clutch, so one or both could run work better? almost half the engine fictional and pumping losses. both could be kept warm by one, ready if needed at the next mountain.
Old 02-12-2008, 11:52 PM   #23 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Good, good, good, good vibrations! (P.S. I really mean bad vibes)
-If you've ever had to synchronize multi-engined equipment, you know what I mean.
Old 02-13-2008, 12:26 AM   #24 (permalink)
RH77's Avatar
Somewhat off-topic
Does anyone remember the "Push-Pull" Chevy Citation X11 with 2 engines: front and rear ('85 I think)?
This is an interesting idea -- as AWD hybrids are generally driven at the rear wheels by electric motors along with the CVT/Gas-Engine up front.
I wonder how 2 small engines would fair in a real-world application... A small diesel on both ends: both work for acceleration from a standing start and one for cruise. Brainstorming over here...
RH77
EF5 / 22-May-2011
_
_
Old 02-13-2008, 01:37 AM   #25 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
I have considered such a beast before and decided that the engine(s) either need to be split from within a common block, or be close enough together to share coolant and oil so as to keep the "part-time" stuff hot for when it's called to action. Letting the part-time stuff go cold all the time would be bad.
Then there is the vibes problem, they really need to be indexed to each other somehow or very disagreeable vibes will result... I think.
Old 02-13-2008, 04:51 AM   #26 (permalink)
DAN
do not grind off the cam. set the valves. i once fad a shop grind down the fact shims. waste of money, the valves were shot
Old 02-13-2008, 05:05 AM   #27 (permalink)
DAN
just about everyone has Cylinder Deactivation. it works. long ago ford said they were working on one that only shut off fuel to 3 of 6 Cylinders i've been tring to find info on it. i think (maybe) you could ground out some of the injecters and Deactivate that way.
Old 02-13-2008, 02:11 PM   #28 (permalink)
MP$
i have extra cams. #2 chamber has a coolant leak any way. so i'll just weld or epoxy that. i going to use 1 & 4 so even fire, and a nasty rocking couple.
Old 02-13-2008, 03:37 PM   #29 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
John: I've disabled 1 & 4, and 2 & 3, and there was no noticeable difference in "rocking couple" vibes.
Old 02-13-2008, 05:01 PM   #30 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
Originally Posted by RH77 View Post
Does anyone remember the "Push-Pull" Chevy Citation X11 with 2 engines: front and rear ('85 I think)?... RH77
A related story. Not an FE project, I'm sure - but two engines, front and rear.
Pop Mechanics or Car and Driver or one of those... built a two engine car based on a fwd, 4-cyl compact. Probably n the '80's. I thought it was a Honda or maybe an Escort. Anyway, they added a duplicate engine in the rear, complete with stock fwd drivetrain. I think it had to be an automatic, since coordinating two linkages + clutches would be a project in itself. As I recall they had to move the gas tank and also did some suspension work so it would handle decently. Apparently it went like a bat out of heck.
No link between the two engines/drivetrains other than a throttle cable. And the tire/road interface.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 04:32 PM
How Many Automatics out There? (FE techniques discussion) RH77 EcoModding Central 18 02-07-2008 11:50 PM
