Old 10-08-2009, 01:42 AM   #61 (permalink)
I've had a couple Cadillac rentals lately they use variable displacement, the CTX got a easy 32 MPG cruising at 70 to 75. The Northstar line is the followup to the failed V8/6/4 from back in the day..
They don't shut down 4 cyl or any cylinders really, they strategically skip the injector pulse in a order calculated to skip each cylinder in a manner to not un-balance the power cycle of the engine. This means that at cruise and no load it can effectively be only firing only part of the cylinders, I've heard the caddy will EOC itself on a downhill run. Its still spining but under highly reduced load. I think it even opens the torque converter lockup when coasting.
Dave
Old 10-08-2009, 01:54 AM   #62 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
That isn't how DOD works.
Old 11-03-2009, 11:39 AM   #63 (permalink)
Hey Frank, and others, now Doug Palmear is claiming his invention is a hybrid, AND he can deactivate up to 7 of 8 cylinders? Is he still full of horse manure?
http://ecomodder.com/forum/137482-post72.html
Old 11-03-2009, 01:11 PM   #64 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
With only two batteries! He must have filled them with E85 to create super-batteries???
Old 11-03-2009, 07:02 PM   #65 (permalink)
I read up a bit on cylinder deactivation, and perused this thread. The concept is interesting, but doesn't sound simple. I fail to see how Doug could choose how many cylinders to use.......say from just one all the way to 8......
And I learned that spiral core batteries are nothing but a better lead acid battery..... He'd need a ton of them to achieve the voltage needed to help boost the fuel economy as high as he's been touting....
Old 11-03-2009, 08:31 PM   #66 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Horse manure may be the answer.
% eff.? % eff.? % eff.?
E85->fuel cell->lectric->var. freq. drive->direct drive motor
engine sound generator and speaker, no engine.
Old 11-05-2009, 04:17 PM   #67 (permalink)
This blogger reports from SEMA..... My comments in italics
Truth with Speedzzter (including commentary on Ford Motor Co.)
LAS VEGAS -- At the 2009 Specialty Equipment Market Association Show, HP2g.com released more details about its revolutionary 110 m.p.g. electric hybrid V8 Ford Mustang. Doug Pelmear’s innovative 4.8 liter V8 engine uses electronically-managed variable displacement and an integrated pulsed electric motor to vary output for conditions and power demand. The naturally-aspirated HP2g engine can produce as much as 400 horsepower and 500 lbs/ft of torque during acceleration and as little as 15 horsepower during part throttle cruise conditions. The engine is computer managed.
The revolution in HP2g’s powerplant is three-fold. First, according to HP2g’s press release, “[T]he HP2g E-85 fueled engine can transition from running on all eight cylinders down to firing on just one.” Unlike conventional variable displacement systems now in production, the HP2g’s engine rotates the single active cylinder among the eight using a proprietary process.
Love to see everyone's comments on that, and below as well
Second, HP2g reportedly has integrated a unique electric motor which operates “on a pulse basis, instead of what is called full saturation.” HP2g uses rapid electric cycling to conserve electric energy. The integrated motor also reportedly employs regenerative braking. The battery pack for the pulsed electric motor is reportedly two racing spiral core gel batteries.
wouldn't that be 24 volts? Far from what's needed to supply much power assist, right?
Third, HP2g has discovered “added efficiencies because of tight tolerances and sturdy design.”
Cool, that might give another what, 3-5% gains?
Old 11-05-2009, 07:29 PM   #68 (permalink)
MP$
so he has 8 one cylinder engines...
aren't most variable drives pulse drives now...
and he burns E85 at 100% efficiency...
Pulse and Glide Fuel Economy Calculator 4 valve / Cylinder newtonsfirstlaw DIY / How-to 25 11-04-2008 03:32 PM
How Many Automatics out There? (FE techniques discussion) RH77 EcoModding Central 18 02-07-2008 10:50 PM
