Old 05-20-2014, 11:21 PM   #1 (permalink)
Rob.'s Avatar
Smile D.I.Y. Engine Bay cleaning using WD-40 (pics)
Hey everyone, I wanted to share with you an easy cost effective way of cleaning rustproofing off your engine bay.
I used WD-40 and a paintbrush and 4 microfiber towels.
Works amazing on 20 year old buildup of dirt and rustproofing. No joke. =)
Car had been sitting for 10+ years.. I basically spent 4 afternoons/evenings total on it.
Here is a recent cleaning on my 1991 civic si.
STEP BY STEP
1. Go to the automotive store, buy 2 cans of WD-40 , 4 microfiber towels, paintbrush.
2. Open Hood.
3. remove battery, air filter box and arm, fuse box cover, wiper motor, map sensors assembly, coolant overflow tank, move away side wires and tubes on shock towers.
4. Start attacking the dirtiest parts with WD-40.
5. Spray and brush/agitate the grime/dirt
6. Wipe off dirt with towel.
7. Once all the bay is clean, you can buff and polish the paint around the bay and dress the rubber hoses with rubber and vynil dressing.
Keep doing this until all dirt is removed. It takes a while, but well worth it.
WD-40 wont remove the paint.
Time involved: Roughly 20 hours.
Of Note: As you will notice, some parts were replaced/restored as well.
BEFORE:
AFTER
The Following 2 Users Say Thank You to Rob. For This Useful Post:
Cobb (05-21-2014), slime (01-21-2020)
Old 05-20-2014, 11:31 PM   #2 (permalink)
I'm seeing a lot of rusty cadmium plated parts in the before picture that are not rusty in the after pictures. The after pictures look too good to be true. It was filthy before but to get to the after condition you would have to replace a lot of parts. The left engine mount was covered in rust, was it replaced?
Can you name the replaced parts?
regards
Mech
Old 05-20-2014, 11:33 PM   #3 (permalink)
Rob.'s Avatar
regards
Mech
DID YOU NOT READ ? Yes, parts were replaced.
The Following User Says Thank You to Rob. For This Useful Post:
Cobb (05-21-2014)
Old 05-20-2014, 11:34 PM   #4 (permalink)
Stickers on the battery and the front of the timing belt cover are not the same. Rusty radiator hose clamps. Rusty bolts on the exhaust manifold heat shield. Wd40 wont clean that rust off and make them look new.
regards
Mech
Old 05-20-2014, 11:37 PM   #5 (permalink)
Name the parts you replaced, instead of trying to belittle my reading skills. It's not the same car.
Old 05-20-2014, 11:38 PM   #6 (permalink)
Rob.'s Avatar
Originally Posted by old mechanic View Post
stickers on the battery and the front of the timing belt cover are not the same. Rusty radiator hose clamps. Rusty bolts on the exhaust manifold heat shield. Wd40 wont clean that rust off and make them look new.
Regards
mech
All replaced.
Old 05-20-2014, 11:39 PM   #7 (permalink)
Rob.'s Avatar
same car jackass
slime (01-21-2020)
Old 05-20-2014, 11:39 PM   #8 (permalink)
If what you say is true then your claim of cleaning with WD40 should be changed to an engine compartment restoration and I doubt it.
Old 05-20-2014, 11:41 PM   #9 (permalink)
Now whose communication skills are toilet based.
The Following 3 Users Say Thank You to user removed For This Useful Post:
Cobb (05-21-2014), elhigh (05-27-2014), maczo (05-21-2014)
Old 05-20-2014, 11:43 PM   #10 (permalink)
Rob.'s Avatar
Judging by the cars you own, I dont take anything you say with a grain of salt.
I really do not care what you think, or if you believe in God or not.
I posted a thread to show how to remove 20+ year buildup of rustproofing with WD40.
ALL MY COLLECTIONS ARE FAKE TOO RIGHT ?
https://www.flickr.com/photos/robcrx/sets/
