Old 07-22-2008, 08:25 PM   #21 (permalink)
amateur mech. engineer
Sporty Accord - '88 Accord LXi
90 day: 23.25 mpg (US)
Dad's Camry - '01 Camry CE
90 day: 22.81 mpg (US)
Artie's Camry - '98 Camry
90 day: 37.3 mpg (US)
The vacuum at idle seems too low. Usually it is about 20 inches. Maybe your timing belt has been installed incorrectly. Try taking off the belt cover and checking the timing marks for the camshaft sprocket. Be sure to reset the ignition timing if you change the valve timing.
If you can put a high input impedance voltmeter (such as a digital voltmeter) in the car and connect it to the oxygen sensor with a long wire, it may help you to find out if the fuel mixture is correct. A passenger could read it while you drive.
What is the meaning of VS+ and IP+? Are these oxygen sensor signals? I'm thinking that the signal on IP+ may indicate that the mixture is rich when you have surging.
Last edited by Andyman; 07-22-2008 at 08:40 PM.. Reason: question to ask, punctuation
Old 08-07-2008, 04:46 PM   #22 (permalink)
CRX HF Vtec-e
CRvX HF - '90 CRX HF
Ok, so I finally got it this problem sorted out. After all the fuss about the laf sensor, it turned out to be an improperly install tps. The tps sensor should register .5v with the engine off and throttle closed and 4.5 at wot. Mine was 0v until part throttle, at which point the voltage would come up to the idle point and cause the engine to start surging as the ecu tried to compensate for lean/rich with the injectors.
New problem though. Engine runs really well, however i took it out for ~15mi test drive on the highway and when i go up a hill in 3rd gear the engine will start blowing blue smoke. If i lay off the engine for a second it'll go away. But's it's definitely a plume of blue smoke.
I don't know whether it's because it's a jdm motor and i just need to run some miles through it to clean it out or whether it's the valve stem seals that need replacing. I guess I could throw some seafoam in there too...open to other suggestions as well.
Old 08-07-2008, 05:13 PM   #23 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Weird on the TPS, I've heard of them getting out of whack but never like such (I guess it's different on the z1 though). I'd try for the seafoam and see what's up. Bummer
Old 08-08-2008, 12:39 PM   #24 (permalink)
CRX HF Vtec-e
I'm planning on seafoaming it later today and putting some more miles on it and hopefully it goes away. In the mean time it passed ca smog this morning with flying colors. Now I'm off to register it....
Old 08-11-2008, 12:21 PM   #25 (permalink)
This could be a problem with the PCV system. If there is too much leakage past the pistons, it could carry some oil through the PCV hose and into the air intake. You could check the compression pressure. Lower than normal pressure means something is leaking or the valve timing is wrong. A higher viscosity oil could help to reduce this problem.
Old 08-11-2008, 12:31 PM   #26 (permalink)
CRX HF Vtec-e
yup checking compression is next up. I seafoamed it, but it's still doing it, although not as bad. I drove it 90 miles and it did it twice. Each time the engine was under load around 3200-3500 rpm ( I live in the mountains and clearing multi-thousand foot passes is a way of life). I just held the throttle position and it stopped after about 5 seconds. I can smell the oil burning before it happens too, and then POOF! I haven't ruled out an external leak onto the exhaust manifold either. BTW, I'm running synthentic oil in there, so I may switch to regular and see if it clears up too. Who knows...
Old 08-18-2008, 10:15 PM   #27 (permalink)
CRX HF Vtec-e
Ok, figured out what was going on. Somehow (I have to be at fault here since I filled it) an extra quart of oil ended up in the engine. I drained it to the appropriate level and problem solved. I also ended up seafoaming the engine...twice...and boy does it run pertty now
Old 08-18-2008, 10:20 PM   #28 (permalink)
Dartmouth 2010
SVOboy's Avatar
Always check the simple stuff, eh?
Old 10-14-2008, 07:08 PM   #29 (permalink)
EG6 - '-1808 Civic VX
Unhappy Alright I need Vacuum Diagrams/ Oxygen Sensor Diagram
so i installed my D15Z1 but i didn't realize that i was missing some hoses i bought the hoses but don't know where they go? and help? i have no clue where my EGR valve connects to?
also my oxygen sensor wires were cut and i need to rewire them. can anybody help me... please.
Email me with any help at toxcma05@aol.com
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 75 05-24-2011 02:34 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
