Old 09-26-2011, 09:52 AM   #211 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Congrats - 65.3 mpg-e is your best tank yet!
Old 09-26-2011, 10:55 AM   #212 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Yep, it is far above my normal average in summer of ~55mpg. Its also a bit impressive due to the colder weather we've been having. I havne't started using the block heater yet, but its use is not far away.
Old 11-23-2011, 08:10 PM   #213 (permalink)
HamiltonianOperator's Avatar
Heating/Cooling for Li+ Batt Packs W/turbine
Hello, I enjoyed Reading your forum.
Are there any updates? Forget Thanksgiving, work on your car
___
I was curious about the heating and cooling issues, being from Michigan myself.
I was wondering if anyone has considered running a vacuum pump instead of w/ a belt, with some kind of compression turbine possibly run from exhaust, like a turbo? The clear advantages are to have a higher pressure line and vacuum line, the exhaust manifold would have to be modified, this could then (possibly) be used to directly to heat other components as well as power the car's stock condenser. As an owner of a celica I am not sure how the AC vacuum/ compressor is/are set up and I wouldn't be surprised if you could disconnect your AC belt for increased summer driving economy.
Anyone know if a scan gauge can work with an 03 celica or what will? There are a lot of wire harnesses but I can't find any parts online for mpg meters.
-AP
Old 11-23-2011, 08:53 PM   #214 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
A scan gauge will work with any oby2 car. So from 96 on it should work.
Old 11-24-2011, 08:37 AM   #215 (permalink)
CM400E - '81 CM400E
The only heating/cooling issues there are is since my commute is so short and I use EV mode as much as I can the car doesn't really warm up well in winter. Max coolant temp rarely hits 160F.
Daox's 1997 Paseo Build Thread Daox EcoModding Central 239 11-24-2011 08:44 AM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Daox's 2003 Matrix Build Thread Daox EcoModding Central 74 09-17-2009 08:22 PM
Toyota Drops Prius Base Price to $21,000 to Compete with Honda Insight SVOboy EcoModder Blog Discussion 5 04-22-2009 12:50 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
