11-29-2012, 03:17 PM
#11 (permalink)
I tried it with tape one time and just kept adding til it was completely blocked and used my sg2 to watch temp. Ive also added a bottle of water wetter to the antifreeze and put the amount needed to be removed from the rad into the over flow bottle.
Yeah. does wonders for acceleration at 50-70mph with the seat of the pants dyno.
Its also nice to have the heat a degree from max and still maintain normal operating temperature, fuel economy and other IMA behavior when its freezing or below out. I have MS so heavy clothing is out of the question.
12-14-2012, 01:48 PM
#12 (permalink)
For the first time since installing the grill block I had the car on the highway for a reasonable amount of time. I noticed the full grill block certainly did its job. The ambient temperature was around 45F out. It took a little while, but the coolant temp just kept going up and up until around about 204F / 95.5C the radiator fan kicked on and the coolant temp quickly dropped down to around 190F. After that I turned the heat on and that kept the coolant temps in check. At lower speeds (45mph and less) I would be willing to bet the cooling fan would probably never come on.
Looks like that actuated grill block will be coming in handy every once in a while even in winter.
12-15-2012, 06:31 PM
#13 (permalink)
How are the other cooling systems doing? I think I heard or saw a second cooling system for the inverter and maybe another for mg2 if I am not mistaken?
Yes, its nice to have toasty heat in freezing temperatures and still able to use ev mode, autostop, etc from a hybrid.
12-16-2012, 09:24 AM
#14 (permalink)
As it is right now I'm not monitoring inverter temperatures. After this experience I will be looking for some x-gauges to program into the scangauge to try to get something. I've been told at the least I can get MG1 & 2 (motor generator) temperatures. However, after hearing what kind of temperatures they operate at I'm not really concerned much.
12-16-2012, 10:15 AM
#15 (permalink)
EV test pilot
Pssst.
Let me know how to set up my scanguage for the inverter temperature when you do!
12-16-2012, 02:08 PM
#16 (permalink)
Left Lane Ecodriver
I found this very long list of X-Gauges for the Prius. The four that I've tried so far appear to be working correctly.
https://docs.google.com/spreadsheet/...zdnhhbmc#gid=0
The Following User Says Thank You to RobertSmalls For This Useful Post:
12-16-2012, 07:59 PM
#17 (permalink)
FWIT I sat in my insight with a space heater trying all of those included ones for afr and lean burn, etc and none of them worked. This is with the latest update too.
Originally Posted by RobertSmalls
12-16-2012, 08:02 PM
#18 (permalink)
Codes are different for every manufacturer and probably even differ from model to model in some cases.
01-05-2013, 10:37 AM
#19 (permalink)
Daox,
Have you been able to monitor inverter temps yet?
I have a 2012 Prius now and I used the insulation foam to block 100% of the lower grille (radiator) but left the upper grille (inverter) unblocked. Under normal highway driving at 29F-55F and <70mph my coolant temps are 191-195F. Going uphill on my morning commute temps may get to 198F as long as temps stay below 50F. At 60F I saw temp rise to 202F then drop back to 195F pretty quickly. I feel I have a good handle on coolant temps now but I am concerned with inverter temps and my Scangauge has not been updated since 2006 and won't accept xgauges for my 2012.
I made the mistake of driving to LA at 75-85mph with the grille block on and when I hit the grapevine my temps climbed to 211F before I realized there was a problem. Despite temps in the low 50s, the grille block was obviously too much. Just a reminder so you guys don't do what I did. Make sure you have the tools needed to remove your grille block at a moments notice.
01-05-2013, 07:18 PM
#20 (permalink)
I still haven't bothered to try anything out. My daily commute is 7 miles at a top speed of 45 mph. In winter I get up to temp, and all the excess heat goes to heating the cabin. There is no chance of overheating.
That being said, this weekend I took a trip across state. Half of the trip was 55 mph country roads. With the heat set to max hot, and the fan on about 1/4 speed the fan came on about 3 times. At 60 mph the coolant temps rose a lot faster and I needed to pull one of the foam pieces out of the upper grill.
