Datsun 120y coupe?
I have been thinking one of these old Datsuns might have good aero shap well at least the roof line to the back of the car. Have a look at these pics and tell me if you think it should have good attached airflow from the front of the roof to the backend?
http://i537.photobucket.com/albums/f...ps2d234a52.jpg http://i537.photobucket.com/albums/f...pseabb526e.jpg Thanks Jamie |
The back looks good, but I'd check for attached flow over the hood first. If there is a big air swirl in the middle of the hood, it will benefit from some front end work. Such as a short bullet nose.
Is that the same car as the Datsun B210 that used to be sold in the States? |
Yeah it's the B210 here, Sunny in Japan. In fact, my desktop wallpaper is a purple B210 Excellent. :D
Rear end looks abnormally good for a 70's car but you'll need to redesign the front end if you hope for aerodynamics. This air dam would be a good start: http://www.ztherapy.com/bios/images/b210b.jpg Vortexes off the sides may be a problem, though. Hard to know for sure though. There's a guy on here that ecomodded a B210... screenname is blownb310. (In the US, the B310 generation was confusingly named "210". They did this with Bluebirds too...) |
1 Attachment(s)
I've watched a couple of these on ebay, but I don't need another project that I'll never finish.:o
The back looks good, the front would need a little bit of work if you're serious about aero. The great thing about Datsun/Nissan is that there's plenty of options for engine, transmission and rear end swaps. I've seen it referred to as "Giant Lego".:D |
Xist - template looks about as close as a Prius/Insight.
The car sure looks like it has potential. |
IMHO the roofline profile is the only thing it has going for it. There's no taper in plan; and if the body below the beltline was flipped upside down and the roof reattached it would be an improvement, e.g., lower the stagnation point.
Datsun
I don't have that car in a true-length image,so It's hard to 'analyze' it,but I do have the 1976 Plymouth Arrow of which the roofline is similar and lacks very little aerodynamically.
*The Arrow returned 37 mpg HWY for Popular Science Magazine's road test. *The X-Ray image revealed that the hoodline and nose could be lowered significantly and still contain all the original mechanicals. *Hucho demonstrated that very little leading edge radii would allow for completely attached flow in the front and it would be a snap for the Datsun. *With a 'cleanup' you ought to easily see low,to mid 40s mpg. *I'd give it a thumbs up as a project car.:thumbup: |
Rake it. Nose down it will have better compliance to the Template.
How much are you willing to extend the length front or rear? I mean, if you had one. A bullet nose (carved back or added on), belly pan, rear diffuser/boattail, and work on the wheel wells would return dividends. There's a pretty heavy shadow under the rain gutter on the A-pillar. Here's what the Porsche 911 folk do: http://www.gerrelt.nl/section-aerody...windnoise.html They claim 5 km/h more top speed. I don't know what that translates to in Cd, but it will help with wind noise at the very least. |
I guess that the previous model was called the 1200 and supposedly had a Cd of 0.42
Tech Wiki - Aerodynamics : Datsun 1200 Club |
