Old 06-28-2017, 12:10 AM   #11 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Originally Posted by Hypochondriac View Post
I have a 2000 accord automatic transmission. I use the Torque app with a blue tooth OBD2. Torque has a fuel consumption display. It shows the same amount if I'm coasting in gear or in neutral so it looks like I don't have DFCO. Any other way to see if my car has DFCO
I've used the torque app and the scangauge on both my cars and found the torque gauges don't show DCFO but the scangauge does. I know both my cars have it so must be a problem with the torque programming.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 06-28-2017, 12:14 AM   #12 (permalink)
puddleglum's Avatar
Originally Posted by JockoT View Post
Tried it in third, this morning, and though revs dropped down from 2500 to stalling I felt absolutely nothing!
I find I usually can't feel it kick back in unless I'm on a bit of a downhill.
Old 06-28-2017, 12:20 AM   #13 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
I feel it sometimes, and sometimes I don't feel it. That goes both for cut-off and cut-on.
Old 06-28-2017, 06:07 AM   #14 (permalink)
Honda - '00 Honda Accord
90 day: 22.95 mpg (US)
Thanks. Does Scangauge actually have a field called Dfco, or are you looking at reading and inferring from that?
Old 06-28-2017, 06:26 AM   #15 (permalink)
Joggernot's Avatar
I have a 2000 Accord V6 and definitely have DFCO as noted on the ScanGage II mpg. Rpm up to 2000 and let of the gas. With the automatic I can down shift all the way to first gear and keep DFCO as long as the rpm's don't drop below 1200.
Old 06-28-2017, 07:03 AM   #16 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
0 Load = DFCO, you don't need a specific parameter for it.
Old 06-28-2017, 07:20 AM   #17 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Right enough. On the ScanGauge Load or LOD is the percentage of power being generated and if the cut off is engaged that will be zero. At tick-over there will be some small amount of power or LOD displayed.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 06-28-2017, 08:34 AM   #18 (permalink)
When you guys say load. You mean Engine Load or something else?
Old 06-29-2017, 12:25 PM   #19 (permalink)
puddleglum's Avatar
Yes engine load. Instant lhk will go to 0 as well or 99999 mpg.
Old 06-29-2017, 06:24 PM   #20 (permalink)
I read that for automatics to enter dfco you have to be in d3. Does anyonr know if that's true? I haven't tested it yet. I'm worried if I shift into d3 whie driving I'll ruin the transmission
