Old 06-26-2017, 02:10 PM   #1 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Deceleration Fuel Cut Off
Does the electronic fuel injection on my 1.2 i-DSI Honda Jazz/Fit GD-5 have a "shut off on overrun" and if so, above what rpm does it work?
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 06-26-2017, 02:31 PM   #2 (permalink)
I'm sure it does, and it normally starts spraying fuel around 900-1500 rpm. If you have it in gear and coast down, you can feel the jerk as it kicks back in.
Old 06-26-2017, 03:24 PM   #3 (permalink)
JockoT's Avatar
Thanks. I take it I am more likely to feel the jerk in a lower gear?
Old 06-26-2017, 03:43 PM   #4 (permalink)
Yes, but it'll also be at a lower speed in a lower gear. You should still be able to feel it in a higher gear.
Old 06-26-2017, 09:11 PM   #5 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Use a shallow sloping hill and top gear, you'll feel exactly when the fuel comes back in.
Old 06-27-2017, 12:35 AM   #6 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I like checking in first gear. Much easier to feel the fuel kick back in. Also safer to be staring at the tach at lower speeds.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 06-27-2017, 02:05 AM   #7 (permalink)
JockoT's Avatar
Tried it in third, this morning, and though revs dropped down from 2500 to stalling I felt absolutely nothing!
Old 06-27-2017, 08:30 AM   #8 (permalink)
Was the engine warmed up? If you're still in high idle mode, it won't kick in.
Old 06-27-2017, 11:30 AM   #9 (permalink)
JockoT's Avatar
It had warmed up and tick-over was about 700 rpm, but I'll try it again after a good few miles when engine is really hot.
Old 06-27-2017, 06:53 PM   #10 (permalink)
Honda - '00 Honda Accord
90 day: 22.95 mpg (US)
I have a 2000 accord automatic transmission. I use the Torque app with a blue tooth OBD2. Torque has a fuel consumption display. It shows the same amount if I'm coasting in gear or in neutral so it looks like I don't have DFCO. Any other way to see if my car has DFCO
