Old 02-28-2011, 09:40 PM   #31 (permalink)
sc1 - '98 sc1
90 day: 46.37 mpg (US)
Tour bike - '011 Carp line Tour
What size tires you have, they look like they fill the wheel well nicely.
- Tony
Old 02-28-2011, 11:56 PM   #32 (permalink)
Aero Sol - '93 Del Sol GSR
90 day: 40.31 mpg (US)
They are 205/50 R15... a bit fat in terms of ecomodding, but they are left over from my days of souping up my car. Once the tread wears out, i'll most likely switch to a Low Rolling Resistance tire.
Old 01-31-2012, 11:47 PM   #33 (permalink)
version 2.0
the belly pan as it is was not very sturdy. it's always got caught in the wind and the choroplasr melted near the transmission and engine. therefore I decided to build a frame out of aluminum to make it more stable.
the frame is made out of aluminum screen door frame found at home depot. it is sturdy because of the box shape, lightweight, and cheap.
5/16 in. x 3/4 in. x 84 in. Aluminum Screen Frame-3021650 at The Home Depot
the main goal was to use pre existing holes and not drill into the body.
First, I made 4 horizontal braces. I used pop toggles from home depot to drill into the pre existing holes that are originally for the side skirts
Front of the car brace. It's attached to existing tow hooks
From the back
Old 02-01-2012, 12:00 AM   #34 (permalink)
Next is 2 parallel bars down the back. I plan on covering the exhaust with aluminum sheets
NEXT step is to attach the middle bars to the rear horizontal bar
Then, tomorrow, attaching all of the choroplast back on.
I gave it a few tugs, and its actually very sturdy!
The Following User Says Thank You to jedi_sol For This Useful Post:
COcyclist (02-01-2012)
Old 02-01-2012, 08:12 AM   #35 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
What do you plan on doing about the melting issue?
Old 02-01-2012, 03:33 PM   #36 (permalink)
I'm.going to cut out the melted.sections and replace.with aluminum sheets
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
My new car. Honda Del Sol pgfpro Introductions 4 08-29-2009 01:28 AM
1993 Honda Del Sol conversion delsolectric Fossil Fuel Free 5 06-09-2009 12:18 PM
Regearing my Honda (1994 Del Sol VTEC) Shortie771 EcoModding Central 79 06-05-2009 01:04 PM
aeromodding del sol track car MazdaMatt EcoModding Central 8 07-23-2008 05:51 PM
