Old 11-26-2010, 11:43 PM   #1 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
destroking engine. any ideas on how to reduce 2.2l down to 1 or 1.5l
Hi all,
Well i am stuck with a 2.2l engine, i have done plenty of modifications but the limiting factor is starting to be the engine itself. A 2.2l has much more power than i need. I toyed with the idea of deactivating the cylinders but the balancing and infrequent power makes the engine vibrate and generally doesn't ride very well.
So short of changing the whole engine the only other thing i can think of is to destroke the pistons which i believe involves changing the crank shaft. It sounds like a very difficult job so it may not even be workable but has anyone ever done this. I am wondering if i can just get a crank shaft from another car which will work for my mazda 626 91. also how hard it is to change the crank shaft.
if anyone else has ever tried to get the engine itself more efficient i would be interested to hear what has been tried. I have already heard of changing the cam shaft, piston coatings and lean burn.
thanks
Old 11-27-2010, 03:01 AM   #2 (permalink)
Knight - '07 Cobalt LS
Chevyteg - '95 Integra LS
just swap the motors if its that bad for you
Old 11-27-2010, 03:46 AM   #3 (permalink)
If you change the crankshaft you would have to change pistons and/or rods also to maintain a proper compression ratio. You`d basically be rebuilding the bottom end.
I`m not sure what side effects would result from going to a radically over-square (large bore, short stroke) configuration. Fuel/ignition might need to be retuned to realize any gains in efficiency. (more spark advance?)
If you continue to use the existing intake then it would still be tuned for the same power level (and would be suboptimal for the low-rpm or low-load conditions that I assume you are favoring). In the Italian market, BMW sold (for tax reasons) a destroked (2.0L) version of the 2.3L e30 M3. It lost some torque but peak power remained pretty close, while moving to a higher RPM (192 at 6900, originally 200 at 6750)
If you feel the displacement is too large, how about going to taller gearing?
Old 11-27-2010, 04:44 AM   #4 (permalink)
turquoise - '97 Starlet
90 day: 41.46 mpg (US)
Another aussie..!
You can change to a smaller engine (which would be the second cheapest way), but the easiest and cheapest way is to just sell the 626 and buy something with a smaller engine.
If it has to be 4 doors, look at Toyota Corollas otherwise get a Starlet ($1500) like me.
If I had my time again, I would have tried to find a 'Lean-burn Civic' though I'm not sure these made it to Australia
You can destroke that 2.2L to whatever you want, except the cost would be ridiculously stupid and then the cylinder head ports would be too big for the reduced capacity, thereby reducing volumetric efficiency and then the cam timing would no longer be optimal either, the list goes on and on....
Putting it bluntly, get a different car.
Old 11-27-2010, 07:57 AM   #5 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Getting a different car would also be a convenient way to get a stick shift. And a 144V starter motor.
Old 11-27-2010, 08:07 AM   #6 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 26.89 mpg (US)
+1 for a wise suggestion. A cheap way to do this is to put larger tires on the drive wheels.
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 11-27-2010, 08:15 AM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I agree on all the suggestions besides trying to destroke 50% of the displacement of the engine
Old 11-27-2010, 08:20 AM   #8 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
It's going to be easier to swap engines. Destroking yours is a lot of work, and without re-tuning the intake manifold, cam and such, you'll lose pretty much all low-end torque, leading to no gains in FE, but a loss in power.
If you want to keep the same car, your best bet is taller gearing. A large engine with lots of low-end torque kept at low rpm will do just as well, or possibly better in some cases, than a smaller engine revving higher to do the same work.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 11-27-2010, 08:35 AM   #9 (permalink)
Wiki Writer
bugler - '91 626
Thanks for all the replies,
I was expecting it to be too hard / easier to buy a new car or new engine so its good to hear other people believe the same thing.
I would love to sell my car and get a new one that is more efficient to start with but i am not sure i would be able to sell it at this point (the front end was crumpled in on one side i bashed it out with a hammer so doesn't look too good) and i am enjoying the idea that i can do whatever i like to the car because if i stuff anything up ill just write the car off and get a new one. I am also interested to see how far i can go with a car that has started off being average for fuel efficiency.
regarding taller gearing, i have already started a previous thread on this and apparently it is very difficult to modify the gearing of an automatic transmission. However I do work with a guy that used to design automatic transmissions so i do plan to hit him up for some ideas.
Old 11-27-2010, 08:42 AM   #10 (permalink)
You don't really want to destroke the engine . Forgetting about that ECU, intake, exhaust would be out of tune.
Destroking generally will move power and TQ up in rpm. thats not what you want for eco plus I doubt you get it much lower than 1.9-2.0 with stock OEM parts .
So either try higher gearing or replace with more modern small engine .
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Killing a Diesel - a detailed how-to (much info on commonrail technology) Piwoslaw DIY / How-to 23 02-11-2011 03:21 PM
Engine block heater plug ideas Chalupa102 EcoModding Central 4 12-03-2009 09:07 PM
Engine Insulation GdB EcoModding Central 5 11-30-2009 02:05 AM
Porsche 911 engine swap - ideas? beatr911 EcoModding Central 17 05-30-2008 05:37 PM
