Old 06-12-2008, 08:26 PM   #11 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Originally Posted by ttoyoda View Post
Do not try to start your engine back up (with the starter motor) while the car is moving and in gear. Just putting the key on run will cause the engine to "restart"
I know YOU know this, but someone else reading this site might not.
Good point! I added that into the write-up (which I stole from a yaris forum by the way) so anyone searching for this will read that.
Old 06-12-2008, 11:37 PM   #12 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by SVOboy View Post
"DFCO" is a name some idiot made up for engine braking to make it sound like something magical he discovered.
Wasn't I the one who first pointed it on GS? Edit-Fail... cmpg was first.
P.S. Wayne is a jerk.
P.P.S. DFCO refers to when idle injection resumes during engine braking/coasting/what have ya.
Old 06-12-2008, 11:40 PM   #13 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Eh, you suck too.
Old 06-13-2008, 12:46 AM   #14 (permalink)
Red
Red's Avatar
Easiest way I've found to see if a vehicle has a fuel cut off on decel is to run it up in 2nd gear, let off the gas and lightly apply the brakes. Once you tach down to around 1000 rpm or so you should feel a slight bump as the injectors restart, else nothing will happen. If your civic coded the same way as my Insight, the restart RPM is somewhere around 1200 rpm
Old 06-13-2008, 05:03 AM   #15 (permalink)
roflwaffle's Avatar
Eh, you suck too.
*shakes fist*
Old 06-14-2008, 05:06 AM   #16 (permalink)
roflwaffle's Avatar
Also, in terms of actually contributing something of value, IME manufacturers of cars w/ automatic transmissions tend to have the shift points above the DFCO when warm, so that when decelerating in gear the car doesn't start using fuel/idling until after it's practically stopped.
Old 06-20-2008, 06:21 PM   #17 (permalink)
OfficeLinebacker's Avatar
I read in my factory manual for my 2000 Toyota Camry that the ECU implemented DFCO down to 1200RPM.
ScanGauge seems to think it is dependent on throttle position, which doesn't make sense (when you're stopped the throttle is just as closed as when you let off at speed).
Old 06-20-2008, 10:11 PM   #18 (permalink)
reformed's Avatar
The TPS has to be a part of it because it only works when you are not on the throttle. I think it is a combination of TPS signal and VSS signal, but I haven't done much research on this, thats just a slightly educated guess.
dfco
My Attempt to reach 40mpg. mhmitszach EcoModding Central 51 07-07-2008 09:01 AM
new to EOC homeworkhome53 Hypermiling / EcoDriver's Ed 12 06-05-2008 12:09 PM
Running the AC during P&G - An observation Harpo Hypermiling / EcoDriver's Ed 21 04-14-2008 11:55 AM
