Old 06-12-2008, 01:46 PM   #1 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Dfco
Do the manufacturers do DFCO in manual vehicles? I am wondering if my 92 civic 5 sp has this, anyone know?
Old 06-12-2008, 01:49 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
What is DFCO?
Old 06-12-2008, 01:51 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Oh wait, is that cleanmpg's stupid name for engine braking?
Old 06-12-2008, 01:55 PM   #4 (permalink)
reformed's Avatar
Deceleration fuel cut off. Supposedly, on these cars it should kill fuel when in gear and decelerating down to 1000 RPM, but I don't know how the car would know if you were in gear or not. An automatic I can understand but I'm not too sure on a manual.
Old 06-12-2008, 01:58 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
It's called engine braking. When you're in gear and take your foot off the gas and the engine slows the car down, you are not using any fuel. Any manual can engine brake, and some automatics will do it as well.
"DFCO" is a name some idiot made up for engine braking to make it sound like something magical he discovered.
Old 06-12-2008, 02:08 PM   #6 (permalink)
reformed's Avatar
Yep, you're right. One of these days I'll learn to google before opening my mouth (does that phrase apply to the internet?). I also just learned a technique for figuring out if you have DFCO in your car. I'm about to try this out on the way back to work so this is secondhand info as of this posting:
How to tell if your car has DFCO
Be careful with this test as you may lose Power Steering and Power Brakes during it! Choose the right time and location to perform the test.
On any level or slightly downhill road get up to at least 40 MPH, then start engine braking by keeping the vehicle in gear and letting all the way off the throttle while keeping the clutch disengaged (MT) or keeping the transmission in a gear lower than D (AT). Notice the deceleration force and the sound of the engine.
Now tun off your ignition (This is where you may lose your PS/PB, so be wary!) and watch for any harsher deceleration or change in the pitch of the engine for a few seconds.
If nothing was any different with the ignition turned off then your vehicle uses DFCO. If it decelerated at a different rate or pitch with the ignition off then it does not use DFCO. Do not forget to start your engine back up! But, do not try to start your engine back up (with the starter motor) while the car is moving and in gear. Just putting the key on run will cause the engine to "restart"
Old 06-12-2008, 02:15 PM   #7 (permalink)
Green Machine - '92 Geo Metro XF i
Last 3: 42.66 mpg (US)
Black Ball - '99 Ford Contour SE V6 Auto
Red Baron - '96 Honda Civic HX
yes. I know from tuning these cars that under hard decel it will shut off the injectors. not sure of the threshold
Old 06-12-2008, 02:20 PM   #8 (permalink)
reformed's Avatar
Yea I definitely have to find the parameters of that before I can use it fully to my advantage. The consensus seems to be in the neighborhood of 1000-1200 RPM and above it will kill them for most cars, so for now I'm just going to stick with a guesstimate of about 1k and see what happens.
Old 06-12-2008, 02:25 PM   #9 (permalink)
that sounds about right, and it will depend on the vacuum the engine pulls
Old 06-12-2008, 05:08 PM   #10 (permalink)
ttoyoda's Avatar
Do not try to start your engine back up (with the starter motor) while the car is moving and in gear. Just putting the key on run will cause the engine to "restart"
I know YOU know this, but someone else reading this site might not.
dfco
My Attempt to reach 40mpg. mhmitszach EcoModding Central 51 07-07-2008 09:01 AM
new to EOC homeworkhome53 Hypermiling / EcoDriver's Ed 12 06-05-2008 12:09 PM
Running the AC during P&G - An observation Harpo Hypermiling / EcoDriver's Ed 21 04-14-2008 11:55 AM
