12-10-2014, 09:42 PM
Eco Rodder
35 MPG 1966 Chevelle
I'm new here and thought I would share my project. I know that a 35 MPG goal pales in comparison to some of your achievements, but I think it's a pretty aggressive goal for a old Chevy.
My project started out as a 283 V8/2 speed auto, 2 door Malibu. I weighed it with very little fuel in it prior to tear down and it weighed 3,172 lbs.
I bought an all aluminum 3.8L/220 CI V6 and a 6 speed double overdrive automatic transmission from a 2013 Camaro. The Camaro shows that it weighs approx 3,850 lbs. I never got to weigh the actual doner car.
My goal is to bring the finished project in at around 2,850 lbs. The new engine/trans is a lot lighter then the old iron V8, I have added lighter suspension and brakes, will use lighter weight seats, aluminum radiator, aluminum wheels, fiberglass hood, etc. I don't think the 2,850 lbs will be tough to reach.
The Camaro's EPA rating on the highway was 30 MPG. I believe that my car being approx. 1000 lbs lighter, lowered 2" from stock, a front air dam, and whatever other tweaks I can add, 35 MPG is a realistic goal.
What do you guys think?
12-10-2014, 09:50 PM
Growing up we had a 4 door 1960 Chevy Impala, 2 speed powerglide and 283 v-8, that routinely achieved 20-21 mpg, with 4 people a trunk gull of suitcases at 60-65 mph. Good luck with your project
12-10-2014, 09:52 PM
Sounds like a nice goal but your aero and frontal area are substantially worse. You might be able to out-mpg the Camaro in stop-and-go traffic but out on the highway I doubt it. Of course you can do some aero modding, subtle things like a behind-the-grille partial block, airdam, and whatnot that won't radically alter the appearance.
My '59 Bel Air with 283/'glide gets about 21 but that is at 55 mpg cruise, but more town driving than is usual for me (cruising).
12-10-2014, 10:53 PM
On the highway the weight doesn't matter as much as the aero and I'd think the 2013 Camaro is more aerodynamic then a 66 Chevelle. Even though the 2013 Camaro is rated at 30MPG on the new highway test, the actual raw, uncorrected, old standard, highway rating on it is 41.9 MPG. So driven with a mild foot and kept under 60 mph the v6 2013 Camaro can break 40mpg.
The 3.6 with the 6 speed auto weighs about 550 pounds and an all iron smallblock and powerglide weigh about 750
12-10-2014, 11:25 PM
herp derp Apprentice
assuming 3.6L from the 2013 camaro? or a different 3.8L, and the 2013 camaro trans?
While the weight would be great for performance, mpg wise, im thinking that lowering 2" from stock, and front air dam will have a greater benefit than lighter suspension, brakes, seats, aluminum radiator, aluminum wheels, and fiberglass hood. If mileage is of more importance, i would try to keep the lightweight goodies on a tighter budget, and spend more time and money on the aero tweeks. droolable belly pan maybe http://ecomodder.com/forum/showthrea...ect-29902.html
