Old 10-22-2011, 04:39 PM   #1 (permalink)
Sweetie - '011 Sonata GLS
90 day: 37.06 mpg (US)
HONKR - '94 KLX686
90 day: 59.94 mpg (US)
Didn't know
my Sonata has an 11.3-1 compression ratio!
Sweet huh?
This ain't a war, anymore than a war between men and maggots. Or, dragons and wolves. Or, men riding dragons, throwing wolves at maggots!
Old 10-23-2011, 12:43 AM   #2 (permalink)
starly - '82 starlet DL
90 day: 40.77 mpg (US)
its amazing what modern technology can do these days, my starlets CR is only 9:1, imagine what would happen if i planned my head to get 11:1 on that thing, i would have to run 100ron gas,
sometimes i have always wondered what would happen if they took all this modern technology and put it into an old car like mine,
Old 10-23-2011, 08:29 AM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Amazing, and it runs OK on 85 octane?
I would love to have the fuel / timing map to look at !
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 10-23-2011, 09:30 AM   #4 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
If the engine is direct fuel injection then you have to cooling effect of the fuel being directly injected into the combustion chamber to allow higher compression. Using heat energy otherwise wasted is the real secret to higher efficiency.
Mazda is developing their SkyActive engines to run on compression ratios of 14 to 1 and higher using advanced injection and EGR strategies. That's diesel compression territory.
regards
Mech
Old 10-23-2011, 10:30 AM   #5 (permalink)
HONKR - '94 KLX686
87 octane is fine as the timing will range from -5 to +50 degrees. Not sure on the fuel map but have seen fuel trim from -10 to +10 on the UG.
From what I hear you can safely run lots more compression with Ethanol.
Old 10-23-2011, 11:57 AM   #6 (permalink)
EcoModding Newb
Acura TSX - '06 TSX
90 day: 29.95 mpg (US)
Lafawnda - '01 CBR600 F4i
90 day: 43.18 mpg (US)
Jeep - '02 Liberty Sport
90 day: 18.02 mpg (US)
My bike is recommended to run 87 PON and it has a 12:1 CR. Of course, the engine is only 0.6L
Is that 87 PON?
What kind of mpgs are you seeing in that Sonata and what year is it? The Sonata was on my radar when I was looking to buy a car last year.
Old 10-24-2011, 02:40 PM   #7 (permalink)
In the US, it would be "AKI", which averages the "MON" and "RON" ratings of the fuel. The AKI is 4-5 points lower than the RON rating for any given batch of gasoline.
-soD
Old 10-24-2011, 04:58 PM   #8 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
AKI = AntiKnock Index.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 10-24-2011, 05:54 PM   #9 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
Sweet huh?
Oh, my poor spark plug saddled friends! How on earth do you manage to be satisfied with a compression ratio of only 11.3:1?
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
Old 10-24-2011, 06:03 PM   #10 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
One does wonder.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
