Old 10-06-2008, 06:44 PM   #11 (permalink)
The tadpole layout is neat, but I'd hate to drive it in the rain. Especially with an electric motor, which makes max torque at 0 RPM. It's an issue for turning loops when starting from a dead stop. (A buddy of mine experienced that more than once with his Corbin Sparrow.)
-soD
Old 10-07-2008, 03:52 PM   #12 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by Blister View Post
Unfortunately for me, I'm pretty sure that changing the size and/or horsepower of the engine would bring up problems that I am unable to solve. There's an education/ability issue hidden in there somewhere. Although I operate medium and heavy equipment, I have no mechanic skills or engineering experience. I hate to sound so defeatist but I think the most use I'm going to be in this project is in gathering materials.
It ain't too bad. The front end would probably need to be a foot or two wider/taller to accept a FWD layout, but all told the changes needed aren't too bad. It would also benefit from being a bit longer, so you could add a small trunk, but there isn't anything impossible about modding it. Definitely learn how to weld, and measure stuff w/in an inch of it's life. I think the easiest thing to do would be like Coyote_X did, except start with a half-cut, weld up the new frame for the engine/trans through the current mounts, cut everything else away, then add the wheels/suspension to that and finally the body to the rear of the new frame.
The problem with such a small engine is going to be speed and hill climbing ability. It would be like driving an overloading semi around, except w/o the proper gearing. In the vehicle as designed, the lithium pack/motor make up for this, but w/o 'em it's going to be slow as hell. Anyway, like Coyote_X told me, the hardest part about doing stuff like this is getting around to it in the first place.
