Old 06-21-2009, 12:18 PM   #51 (permalink)
57.4 mpg best trip.
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 41.14 mpg (US)
Send a message via Skype™ to oldbeaver
Hello to all.
As many "posters", I have a non-turbo non-electronic aspirated diesel engine in my car, a Mercedes 300E originally.
As many have posted, it is not an easy task, but I am confident I will succeed.
My method is triple:
Method 1: Using 2 fuel flow meters.
I am developing a system to monitor fuel consumption in real time, using two fuel flow sensors, a donation from a Swiss company.
One is attached to the tank and the other to the return pipe, as many has pointed is necessary in diesel engines.
Analyzing pulse signals in the scope, they are very square, and sensible to acceleration.
This is under development and I am dealing with programming now, donīt have definitive figures. Results will be displayed as every second marginal consumption and mean for the trip.
Method 2: . Using rpm and throttle position sensor.
My engine has a potentiometer for sensing throttle position. The engine is a 6inline RD28 from Nissan. 2.8 liters.
With these only two variables, I will get a second estimation of fuel consupmtion. I have a first model that estimates consupmtion. Data considered so far is bench marks of Bosch injector at different loads and rpms.
Adding speed sensing, I can have a second fuel performance measure. This will be displayed once a second and compute the mean for the trip also.
Method 3: Tank & odometer.
The first thing to have an accurate estimate is to calibrate the tank resistor sensor vs real liters in the tank. I made this by emptying the tank and filling it at slow rate, writing down results every 3 liters approx.
The reserve light turned off when I filled 10.5 liters app. and went on and on until full at a 55 liters. This is different for every car, I would not use it for another Mercedes 300E tank, because my tank was collapsed by a mechanic mistake and inflated later by me. So my tank has not the original shape. However, model is a 3 grade polynomial, with 98% of variance explicated. Available upon request.
Results displayed will be marginal consumption for the last minute and mean consupmtion for the trip. It will use odometer figures also. The mean for the trip of this method will be a very good validation figure.
Summurizing: I will have three (3) independent estimates for performance, which, I hope, will allow me to validate any measures with the others.
My car will serve as laboratory and I hope I will be able to have models for the three methods.
I donīt know how to insert pictures here. But may share some of the engine, of the sensors and of the car upon request.
Good experimenting, OldBeaver.
Viņa del Mar, Chile
Old 06-22-2009, 09:58 AM   #52 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
oldbeaver, sounds like a good plan. do you have a part # for the flow sensors. It is possible to attach pictures to your post by scrolling down to additional options, and then manage attachments. The pictures need to be down sized to conform with the max. size limits, using microsoft photo editor or some such means to manipulate the image. Also one can go into user cp a create a photo gallery. my first diesel was a 1961 190D wish I still had it. It had a throttle plate to create vacuum for the brakes too.
Old 05-21-2011, 12:28 PM   #53 (permalink)
possible flow meter
has anyone looked at any of these ?
www flownetwork com/positive_displacement_flowmeter_dom.html
maybe a smallish one for the fuel return
and next size up for the fuel supply
sorry for the formatting, I just joined, and cant paste links
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 105 04-03-2010 08:25 PM
Poll for Americans: What about Diesel engines? hal9999 General Efficiency Discussion 117 01-07-2009 07:23 AM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
i-dtec (Honda Diesel) RH77 EcoModding Central 22 02-11-2008 01:20 PM
